Coil contact? Thunk rattle noise
Austerity
Evans, Georgia
Well after the previous 48 hours of hell trying to get my lift kit installed, and one stripped out OME front strut, I have it all installed (albeit with one factory strut in the front and a new OME on order).
The first time I had everything assembled I had a rattle/thunk noise on the passenger side. I tore everything back apart assuming it was the nut on the top of the coil/strut assembly.
When I got it out, even though I had torqued that nut down, it turned out that it was cross threaded. It either got cross threaded when my wife tightened it down (and I subsequently put a torque wrench on it), or it got stripped when I tried to remove it, I am assuming when it was installed.
Either way, everything is together and I still have the same noise. It sounds like something is very, very loose and rattle/thunking around.
Is this coil contact? I can't notice any spots on the coil springs because they are so f$$$ed up from two days of compressing springs and prying spring compressor pieces out of them. Did I mention the front install has been pure hell?
Anyway, I'm at my wits end and would like some help trying to figure out what the problem is. Everything I have taken loose has been torqued down to proper specs.
Any ideas? :worthy:
yellocoyote
Tighten your swaybar end links after the KJ weight-bearing and on the ground? That's a common area for noise if it's not done correctly.
Austerity
Evans, Georgia
I thought I did this correctly, and I retightened them. The noise was still there. Then I removed them. The noise is still there.
Am I right in torquing the upper stabilizer link nut to 100 and the lower to 85?
Austerity
Evans, Georgia
There's also a possibility I didn't put the links back on correctly, didn't take photos of that initially. Would that cause this noise?
Austerity
Evans, Georgia
Completely removed the swaybar links again, and the noise is still there. They are not the problem.
EDIT: Also - load bearing KJ on the ground it doesn't appear like the UCA is anywhere near the coil.
Austerity
Evans, Georgia
Got it figured out!! It was a loose nut on the rear upper control arm bushing. Must have always been loose and the lift amplified it.... because I certainly didn't loosen it.
