code p1250 & p2295
jeshoke
need help with code p1250 & p2295. basketball stars unblocked
Engine Code P1250: Fuel Pressure Regulator Control Solenoid Valve Circuit Malfunction
It means that there’s an ongoing problem in the vehicle’s turbocharger system.
Repair or replace the faulty vacuum sensing valve. Repair or replace the faulty SCV valve. Repair or replace the wiring system that leads to the turbocharger system. Repair or replace the stuck turbo wastegate actuator.
You need to give us a bit more detail, what engine, what year, what is the engine running like etc. Fault codes are only half the story.
