chrysler pacifica rev DVD radio in WJ
teckman02
trotwood ohio
i have been wanting a dvd unit in my jeep for a wile but i hate aftermarket radio's. The main reason that why i hate aftermarket is that i hate having to dig through a ton of menus, just to change one little setting plus since my WJ is a limited i have radio wheel controls and don't feel like trying to map them with some control box.
So I did some looking around and found this chrysler pacifica DVD unit on ebay for 100 bucks
The first thing that i did was cut off the pacifica mounting brackets.
i then put the dvd unit in back the jeep and sat the bezel over the radio then traced around it to trim off the extra that i did not need.
Now the finished product.
i still need to do build mounting brackets and add some screens i want to add 1 up front and 2 in the back. also looking at adding the 6 disk DVD changer someplace.
Since i am keeping the install 95% of the install OEM i am looking for detailed wiring diagram's with pinouts of the WK XK and the pacifica radio and entertainment systems. if anyone has them could someone PM me copys please PDF's would work best.
This would also be a cool mod for the KJ also
Snail Farmer
Fairmont, MN
I was looking at your pics. It looks like the cutouts in the face plates of both stereos are exactly the same. I wonder how difficult it would be to just switch the electronics inside the face plate to eliminate the need for cutting. Just thinking out loud. Great idea though, I like it.
teckman02
trotwood ohio
i had thought about something like that but the circuit board for the controls are on the face, the bezel it would just not line up. I will take some pics of how it is together
Snail Farmer
Fairmont, MN
Oh, yeah I knew the circuit boards were on the face, just wasn't sure if it would come close to matching up at all.
teckman02
trotwood ohio
update to the upgrade
if you are thinking about doing this upgrade and dont want to cut up the face try and ind a head unit from a 05-07 town and country
i saw this one on ebay last night :favorites68::emotions122: i should have done a little more research
teckman02
trotwood ohio
chrysler pacifica rev DVD radio in WJ and KJ
update to the on the AV system got some parts a few weeks ago
in the WJ it is getting this screen up front above the head unit there will be 3 maybe 4 cameras wired to it 1 as a backup cam and 2 up front off the bumper
i am in the testing stage for to interface the DVD changer with the radio and the 10 disk cd changer so when i mode the system will auto cycle from the defferent modes.
teckman02
trotwood ohio
i got me some pigtails for the DVD system
the last pic is of the harness that i am splicing in to the main audio harness
in to the dvd C1 harness
side note i have done some testing with the dvd changer and the cd changer the PCI bus will not auto switch from the dvd changer and cd changer so an A/B switch is going to be need to be ran off the PCI bus.
i still need to build the jumper harness but since i have not decided where to mount the DVD changer i have not built it yet
also still have the build the screen harness
teckman02
trotwood ohio
i have had my DVD screen for a few months now and i have just now gotten to test it out i browed a friends bench power supply and hooked up some dvd players to it.
now i just need to get around to mounting it in the jeep.
teckman02
trotwood ohio
picked me up a different DVD changer from a 05-07 town and country
with this one i wont have to trim the bezel at all unlike the one on the Pacifica
