Changed Spark Plugs-MPG Dropped
rocknrun
Statesville, NC
A couple of weeks ago I changed the spark plugs in my recently acquired 04 KJ, which has 89,000 miles on it. The plugs I pulled out were NGK spark plugs and in bad shape; the center electrodes were really worn down, barely sticking out from the ceramic. Put in Autolite Double Platinums and was looking forward to a MPG improvement, instead my MPG has dropped by about 2 MPG. Any ideas?
That is interesting. Why not try another set of stock NGK's and see if it goes back up?
In reality I doubt that new plugs should cause this, maybe a heavier foot, less air pressure in tires? Heavier Jeep?
I run the stock NGK's and change them every 18,000 miles. Those coil packs are hot & tend to eat the electrodes causing wider gap quick.
I don't see how changing the plugs can give you 2mpg less than with old worn plugs. Must be a coincidence with something else?? A lot of little things affect fuel economy.
I am no expert but that's my thoughts.
cplchris
Albany, NY
only thing i could think of if it were the new plugs causing the drop would be an incorrect gap on the new plugs
tboneil24
Chicago
Only thing I can think of is you have a cracked plug. I would think that would throw a misfire code though. Do you have a check engine light?
rocknrun
Statesville, NC
I think Dave and porkchop might be right...probably coincidence. Libertytc, I think I will pick up a set of NGKs and just for giggles try them out and see what happens. The old plugs I pulled out looked so bad I just knew I would get a few more miles out of a tankful so I was disappointed. I drive about 800 miles a week, knew when I bought it the KJ it wouldn't be real thrifty on gas; I'd been Jeepless for several years since I retired the XJ though and wanted my butt out of a Buick (last GM product I'll ever buy) and back into a Jeep :waytogo:
retmil46
Mooresville, NC
X2. Did you check the gap on the new plugs prior to installing them?
A couple years back, my father had a local mechanic change the plugs on his '98 F150 with the 5.4 V8. Thing ran like crap after he got it back. When I dug into it to check it out, not only had the guy used the wrong plugs - he'd installed the plugs for a natural gas engine!!! - out of the 8 plugs, 3 were gapped for a natural gas engine, 3 were gapped for the V6 engine, and only 2 were gapped remotely close to what his engine called for.:freak3:
rocknrun
Statesville, NC
Yep, checked the gap on each of them. Hope your dad never took his truck back to that mechanic!
Banditsteve
North Yorkshire. UK
I think that subconciously you are driving with a slightly heavier foot to see if it feels any better with the new plugs in. New plugs will only improve the mpg if they are set correctly. I think in a couple of weeks you will see an improvement when you forget about them. Steve :smokin:
retmil46
Mooresville, NC
Be forewarned - my father lives just down the road from you in Mooresville - so that same mechanic is in YOUR neck of the woods as well!!
