LoganVickers
- Joined
- Oct 4, 2025
- Messages
- 2
- Reaction score
- 0
245/65/r17 on a 2005 jeep liberty 3.7L 4x4 6 speed. Found a great deal on a full set and wasn’t sure I could fit them without rubbing. Thanks in advance
That is a 29.5 inch tall tire, whereas the stock ones are 29”. I think you can get away with it as long as your tires have more than 1/4” clearance when turning and articulating up and down. If your original springs have sagged a lot, consider new springs and shocks with those tires. The wheels those 17 inch tires are on will make a difference to rubbing too. Did your KJ come with 17” wheels?245/65/r17 on a 2005 jeep liberty 3.7L 4x4 6 speed. Found a great deal on a full set and wasn’t sure I could fit them without rubbing. Thanks in advance
No mine came with 16” I did get them to put on though and have zero problems with rubbing. I Did how ever put a wheel adapter set on because the rims that were already on the tires mounted to a jeep commanderThat is a 29.5 inch tall tire, whereas the stock ones are 29”. I think you can get away with it as long as your tires have more than 1/4” clearance when turning and articulating up and down. If your original springs have sagged a lot, consider new springs and shocks with those tires. The wheels those 17 inch tires are on will make a difference to rubbing too. Did your KJ come with 17” wheels?
