Cabin air blower not blowing
Bikeflyer
Strasburg, PA
When I turn the fan speeds 1-3 I get nothing. 4(max) works as it should. This is a 2005 stock lib so nothing unusual in it. I took the blower control panel out and looked it over(just the dash part) and found nothing amiss. The pneumatics work fine and it makes heat, but no blower in the lower speeds. Is there a bank of resistors/fuses somewhere else? I wouldn't think its the motor because the RPM on wide open is where it should be. Thoughts?
Pippobug
Cambridge, UK
Thanks, I was thinking it might be that. How hard is access to this item?
I's not to hard to access, but it can be a bit fiddly to take off the little security clip, it should take all in all about 10min. I did it to mine.
Fil.
