Bumper winches for your truck
carid
Preferred Vendor
Cranbury, NJ
If you have ever been on the trails pulling yourself back on your feet, you understand that the most important factor about tough situations is getting out of them faster. Winches are made for guys, who seem to always swerve towards the closest mud hole. We offer both hydraulic- and electric-powered winches in all sizes and designs to fill any winching need from 2,500 pounds of pulling power up to almost 20,000 pounds. Winches we sell are equipped with multiple gears that make the most out of each unit's ability and allow pulling at slower speeds when more control is needed or at faster speeds when rapid pulling is best. To learn more you can visit Winches section at CARiD.com.
Rugged Ridge® - Off Road Winch 8500 lbs http://www.carid.com/rugged-ridge-winches/rugged-ridge-winches-4430903.html
Features:
- Durable 5.5 HP series wound motor
- Tough 3-stage planetary gear box with 172.8:1 gear ratio
- Durable 12' all weather cable remote solenoid box
- HD steel cable winch includes 94' of 5/16" diameter wire rope and latched hook
- Performance synthetic rope winch includes 100' of 11/32" 12-strand braid synthetic rope with a breaking force of 16, 550 lbs.
Mile Marker® - Electric Winch 15000 lbs http://www.carid.com/mile-marker-winches/mile-marker-electric-winches-3621165.html
Features:
- 15,000 pound load rating
- 79 feet of 10-millimeter thick aircraft grade cable winding
- 5.5 horsepower
- Weighs only 101 pounds (25% lighter than competitors)
- 12-inch wired remote control allows operation from a safe distance
- 3-stage planetary gear set design
T-Max® - Performance Series Winch PEW-9500 http://www.carid.com/t-max-winches/t-max-performance-series-winch-437475.htm
Features:
- Rated Line Pull: 9500 lbs Single Line
- 6.6 hp 12V Series Wound Motor
- Gear Ratio: 218:1
- Weight 77 Lbs
- Overall Dimensions (L x W x H) 21.2" x 6.3" x 8.6"
- Mounting Bolt Pattern: 10.00” ± 0.015” x 4.50” ± 0.010”
WARN® - 12000 lbs 12V DC ZEON™ 12 Electric Winch http://www.carid.com/warn-winches/warn-zeon-electric-winch-12515677.html
Features:
- 12,000 lb. single line pulling capacity
- Line speed: 30’ per minute under no load and 3.1’ per minute at 12,000 lb. max. load
- Fast and reliable 3-stage planetary gear train with 216:1 gear ratio
- Dimensions: Integrated configuration – 24.25”L x 7.15”D x 10.52”H, Low-profile configuration – 24.25”L x 7.15”D x 7.84”H
- Weight: 98 lbs.
Also you can check installation video here: How to install a winch featuring the WARN ZEON
What do you think about them?
carid
Preferred Vendor
Cranbury, NJ
Warn sale starts today!
Purchase any Warn Provantage Winch and save $50 OFF the original price, buy any Warn Truck Winch and save up to $150 OFF the original price!
HURRY UP, this promo is valid from March 1, 2015 through April 30, 2015.
