Broke speed sensor right off
eric1514
ID, USA
So in preparation of replacing the driver's side lower ball joint, I broke off the speed sensor flush with the hub it was rusted solid to while removing the knuckle. Do you think I can remove the remaining piece without more damage to the hub of should I just bite the bullet and get a new hub?
TIA
Eric
I think Eric the Car Guy on YouTube just posted a short video on this exact thing a few weeks ago. I think he got it by drilling what was left and using an easy-out.
seafish
I was just gonna suggest using precise applications PB Blaster and then drilling out whats left and using an EZ out, but looks like Eroc the Car Guy beat me to it!!! LOL
eric1514
ID, USA
I have no luck with EZ outs. I tried but I ended up drilling it out and collapsing what remained. I hope its OK.
seafish
Probably a good idea to get the right size thread chaser/cleaner and run it in/out before you install the next one .
If you don’t have time to buy one, you can make one by using a thin grinding disc to slot a screw or bolt of the right size and use it as the chaser with a dab of grease on it
eric1514
ID, USA
The threaded side is good. The bore for the sensor is what worries me. There’s a bit of rust in that hole that needs to clean up before the new sensor will slide into it. Normally not a big deal, but everything that falls in that hole ends up in the grease for the bearing. Oh, well.
seafish
A lightly oversized brass brush with grease on it should do the trick nicely.
eric1514
ID, USA
Check if you got every bit and pieces from drilling, out of the hole?
I did the best I could to keep bits of plastic from dropping down into the hub. Then I used a bore brush with some WD-40 on it to clean the hole and some Q-Tips to wipe it off. The new sensor slid in fairly easily with some sil-glyde on it.
2TALL1
Eastern Oregon
So I broke mine off also it was rusted in there.
I just took about a 3” wood screw and screwed it into the broken off plastic piece and used a nail bar and pulled it out. Turned it upside down so nothing would fall into it and used some emery cloth to clean up the hole.
eric1514
ID, USA
For Posterity:
I bought the SKP branded part from Rock Auto. $12.73. I don't usually go cheap, cheap, but I figured 'what the hell'. It's not a difficult part to replace if I have to do it again. It came with all the right plastic connectors except for the first one coming off the hub. I swapped that piece with the one I removed from my Jeep. Everything seems to be working after 150 miles, no codes, so I'm thinking the part is OK.
