Whelan
I basically rebuilt the entire suspension of the summer, finally got the tri-link ball joint support on the differential, and did all the brakes (discs, pads, etc.) I even put a new caliper bracket and bolts on the front left of the car after an issue with seized pins, did the rotor at the same time.
Well about a week ago there is a new noise (less than 5k on the car since the install) and I've heard it before. But I figured I fixed it, the front left wheel when braking lightly gives the whoosh whoosh whoosh, press harder and it stops. I could not get a good video but this one matches the noise pretty well (sound starts around :25).
My hope is that the new caliper just needs some more grease and it's sticking causing the pad to not engage flat along the rotor but I'm open to other suggestions.
https://www.youtube.com/watch?v=-WFcBNcMBMQ
