Block heater operation
Thanks for reminding me. I need to get one of these to install when I change coolant in mine this spring/summer.
Correct Specs on Jeep OEM Block Heater:
I just found the tag that came off my OEM block heater cord..
10 AMP
1250 Watts (125 Volts)
The draw measured by my APC-UPS meter was 430 watts per hour initially.
Keep in mind that the stock cord is kinda thin and you dont want to rip it apart when u drive off, forgetting to unplug it.
I put a reminder card on the shifter plate. "Block heater Plugged In" so I don't drive off while it is still powered. (me often forgetful)
To Protect The Stock OEM Cord, I Used a Strong Husky Tool Replacement Cord to make an under hood extension to the front. (avail home depot)
48156[/ATTACH]"]
The husky cord has only the male end making it easy to feed/cut up to where the OEM block heater cord was.
I then wired in the female end and now it is strong outside and the OEM cord is now protected.
48158[/ATTACH]"]
48160[/ATTACH]"]
Edit- also using a more accurate Kill-A-Watt meter the consumption of the block heater is:
48162[/ATTACH]"]
TwoBobsKJ
Northern Ohio
Nice mod, Tim. Thanks for the pics!
Question: Where does the wire get routed from the freeze plug over to the side of the engine bay - under the exhaust manifold? Going from memory I can only picture one of the freeze plugs and it was pretty close to the exhaust manifold and it would seem there's the possibility of the wire melting. Obviously that doesn't happen or all of you with the block heater would be frustrated with burned wires.
Inquiring minds want to know! :hmm:
Considering I had to do these photos in the dark..I better get 2 likes LOL !!
Yes I needed a bright flashlight to get camera to lock on.... beer please....ha ha..
48164[/ATTACH]"]
No its too cold to remove the airbox to get a clean "shot"..without whiskey...
The last portion of the wire closest to the element, hides under the airbox ~!
But Hey I moved it out for the photo!
It was like a hidden treasure !! LOL..
48166[/ATTACH]"]
48168[/ATTACH]"]
Hope this helps!
chris03kj
Chicago
[ATTACH=full]48170[/ATTACH]
[ATTACH=full]48171[/ATTACH]
Hope this helps!
Thanks for the pictures! They will be very helpful upon me receiving the heater! Dang usps sucking at their jobs once again. Order delivery estimate was Friday(1/10)the original was Saturday(1/11) and I still have no heater. Damn you usps. Do you happen to have a way to describe where the freeze plug I have to remove is? Or how I can access it? That's my only concern...
Chris all of the installation info will be with the actual block heater.
it will make sense once you receive it.
PM sent.
chris03kj
Chicago
Thanks for all of your help! Now it's just waiting on the good ol' snail mail. Will update when the install is complete...as for now, back to those cold rough morning slow starts...again, thanks for everyone's help/advice!
TwoBobsKJ
Northern Ohio
Yes I needed a bright flashlight to get camera to lock on.... beer please....ha ha...
Well, if I could click the Like button twice and give you twice the love I would! :love62:
Great pics, Tim. Thanks for leaving your warm Lazy Boy for us noobs who don't have block heaters. Makes sense now :waytogo:
chris03kj
Chicago
anyone whose installed one...this is the furthest back freeze plug I found, on the passenger side. Is it the correct one? Any quick replies would be appreciated! Under the Libby typing this! Thanks!
Porkchop
Troy Mi
I believe it's the 2nd from the back right behind the motor mount was real easy to get to. I don't have my Libby right now to check it's at the dealer getting a new swing gate and tire carrier sorry can't double check.
chris03kj
Chicago
Well after a long night, finally got the little sucker installed. Wether it works, well that's a different story. We will find that out tomorrow bright early, assuming this hi tech programmable timer works. Thanks for everyone's advice and helpful information!
