Belt length to bypass Power Steering pump temporarily
Discussion in 'KJ General Discussion' started by Nick Davis, Aug 21, 2019.
  1. Nick Davis
    Nick Davis New Member
    Apr 10, 2019
    Baltimore, Maryland
    Ok So I have documented my Power steering issues in another thread. Long story short, my head doesn't have the correct holes tapped into it. That makes the power steering pump impossible to mount without hitting the coolant outlet. I'm wondering if anyone knows the serpentine belt length I would need without it attached to the power steering pump. I need to get it home from my friends so I can start figuring it out. I've tried the 82.5" that is recommend for the A/C delete and it is to long. Does anyone have ANY insight on this.
  2. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,581
    135
    Not sure exactly but can't you run a string around the route you need and measure that?
    LibertyTC likes this.
  3. Nick Davis
    Apr 10, 2019
    Baltimore, Maryland
    Yeah I got 64" and it just seemed very very short and I wanted to see if anyone else had done it.
  4. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,161
    416
    The sting measurement may be good, but if it is laying flat into groove it may be short and may have to consider tensioner?
    Possibly another 2nd belt 1/2 inch longer IDK?
    It's custom issues like this that are frustrating, probably best not not to have me over & permanently fix it LOL..
    [​IMG]
    Just Kidding.
  5. jeeptorino68
    jeeptorino68 Full Access Member
    835
    36
    Nov 28, 2011
    Oregon
    I think it is supposed tod be 80 something inches....? Search, there should be several threads on this already.
  6. JasonJ
    JasonJ Full Access Member
    1,521
    43
    Jul 8, 2013
    Michigan
    How far do you have to travel with it? Might be easier and safer to just pull it with a tow strap. I've done tow/haul runs like that up to about 60 miles without issue- provided the guy in the vehicle being towed stands on the brakes hard enough when he's supposed to.
  7. LibertyTC
    7,161
    416
    Now that I think back to when I changed into a larger steel pulleys on the tensioner, I wish I would have had a cloth measuring tape available.
    They are available in different lengths, and width.
    [​IMG]
  8. Nick Davis
    Apr 10, 2019
    Baltimore, Maryland
    There is a bunch on A/C delete but not Power Steering. I found one guy who claimed he used the A/C delete 82.5" to drive his KJ home after the power steering pump seized. But its no dice for me. I'm Looking at 63"I believe and the belt will be here tomorrow
  9. blackhawk
    blackhawk Full Access Member
    133
    Apr 3, 2013
    Venezuela
    Nice post! Did the 63" belt fit well?
  10. Nick Davis
    Apr 10, 2019
    Baltimore, Maryland
    I am working on installing an Electric Volvo power steering pump. Then on to the belt fitting.
  11. Jeepguy62
    Jeepguy62 New Member
    Apr 16, 2018
    I had an issue just over a year ago, where the pulley came off my power steering pump. I went back and forth to AutoZone (they exchanged them for me without problem) and found the right size to by-pass the pump. Worked fine until I could get a new pump and get it installed.
