I have just recently installed a 2inch BDS Coil lift. Once installed the jeep was taken to the dodge garage for a recall on the lower ball joints, while in the shop i had them retorque all the nuts and bolts that pertained to the coil lift. While driving the KJ offroad and I hit bumps it sounds like the front end is bottoming out (metal on metal, solid stop/hit) I have looked over everything and see nothing that is hitting. Would this be because of bad struts? the jeep has 50k miles on it. 02 renegade...Everthing is tight...i have looked and checked many times......I am not sure what to do here.....everything is smooth and solid on the road....i hit small pot holes and all is tight...but offroad on a bigger bump (like going fast through a field) the front end hits hard....
What is wrong here????
