Thanks for the update LibertyTC! One of the complaints I read about was that the "Driving Distance" reading was way off for some people, as much as 30% - I'm curious to see your results in that department.
Also on that site with reviews it mentioned a correction factor 1.32 i believe.
I think that there will be a way if it is out a bit, as far as distance goes, that you can get the corrections input to the unit.
It does have English setting which is US gallons I believe, and has Metric which is Litres.
It only saves 24 hours of trip data and 300 hours in black box, so if you want to check up how the kj is being driven by someone else you can.
It does take a bit of inputting for mileage and after each fill you must tell it you filled up and how much fuel was taking on according to the pump. That will eventually get those numbers pretty much dead on I am sure.
I am not going to get the moving data for a while yet as Kj is in storage mode for a few more weeks.
Overall so far for the price this unit dispaly is good and I feel over time, once the learning curve is done, and the settings / the data input, this is a sweet deal. I personally am not that worried about distance and trips as much as I wanted to see the extra gauges, oh it did read 14.7 charge volts. Too bad no oil pressure ..that I can see so far.
When I did initially started the unit it stated software "Version 1.1"
They included a small disc and a usb cable wonder what version is on the disc...hmm..no info in manual about disc or upgrading firmware or software. I have to guess here.. I just take down the notebook get the notebook running with disc in it /find location of disc info, plug in usb/ then get the OBDII unit running, and hope for an automatic prompt on the AUtel OBD screen?? will see..
