AC illumination light
thegapgal
Ontario, CA
I have a 2006 Jeep Libertly. The AC indicator light on the dash does not go on when the AC is on. Yet, the indicator light on the rear window defroster does (the buttons sit side by side)
The owners manual only tells me what SIZE bulb to use. It does not tell me how to replace the bulb.
How do I remove the front panel to do this??? HELP!!!
Porkchop
Troy Mi
Take the screw out on the bottom cubby hole and gently pry out the plastic covering the radio and A/C controls. Im sure you'll figure it out fro there.
thegapgal
Ontario, CA
Thank you !!! Do you happen to know what size bulb?? I will pick one up while I am out . Thanks again!!
Porkchop
Troy Mi
Only place I've found them here has been the dealer and dealer parts are real cheap in Mi and if they don't have it they will by mid day the next day.
