AC compressor replacement.
8675309
MA
I have a 2006 Jeep Liberty CRD, that I purchased about three months ago.
It's hot out, and I'm trying to keep my cool, but... when I turn the AC on, something smells like it is burning under the hood.
The AC blows out cold air, and the compressor clutch is engaging -but it keeps engaging/disengaging every few seconds.
I see no residue around the compressor moving parts -meaning no melted plastic or grease from bearings, etc.
My guess is the coil is somehow melting/burning -maybe the bearings are bad, or the coil "died", or the compressor itself is "bad", or….?
I first tried a $7.99 R134A cheapo charge (I gave it a 5% chance of fixing the problem) -thinking it was low refrigerant (it was a little, but not much). This recharge didn't fix anything (of course)…
I see two options:
1. Replace the compressor -downside is I need to evacuate the AC system, recharge, etc.
2. Get a repair kit (clutch, coil, etc.) -downside is if the compressor is the problem, this will not fix.
I'm leaning towards (1), since I want to fix it once, and not again.
The 3.7L gasoline looks fairly easy to replace (compressor is right on top, near passenger side).
Mine is the 2.8L diesel - I looked around under the hood, expecting the compressor to be on top somewhere, but it's buried down under the engine towards the driver side.
Is this major surgery just to replace the compressor…?
Has anyone done this, and what thing(s) do I need to remove (at a minimum) to get at/replace the compressor?
Should I attempt this from the top, or from underneath?
Thanks,
George
Burning under the hood smells like plastic or oil? Can you see any smoke?
With A/C I always recommend dropping by a pro AC shop for diagnostics firstly.
Adding some refrigerant without accurate gauges, not for me.
Tell them/shop what is up... & see what they may have to say.
There is a way to replace the AC clutch/coil assembly & check clutch gap..Link: http://www.jeepkj.com/forum/f202/how-install-c-clutch-60421/
MA
renegade 04 -I will check this, but I’m sure the compressor (at least the coil) is toast, regardless. I don't dare turn on the AC at this point.
LibertyTC -it smells like burning plastic or epoxy…? There's no visible smoke that I can see. Thanks for the clutch/coil replacement link.
Right now I think my biggest problem is getting the compressor out, to take a look at it. Maybe take the driver-side tire off, and the plastic inside fender, and then I’m able to take the compressor out…?
