ABS light intermittently on. Do I bleed Brakes?
J33Pfan
NY
2002 Liberty v6 Limited 150k miles -All stock
ABS light intermittently comes on from time to time. Do I bleed Brakes? Change the Brake Fluid or is it something else?
Thanks
duderz7
Weiser, ID
Mine did same until I replaced front right wheel bearing and sensor, but the rear one of more likely from what I've heard.
krisP
NY/PA
min did that when wire was rubbing from one of the clips in the rear. a year of that until it came on full time when the wire broke all the way through. Replaced easy
J33Pfan
NY
Fluid Flush didnt remove the ABS light but it sure did remove a lot brown brake fluid!
