So I blew up a rear axle the other day, spiders ate the pinion. Autowrecker has an axle I can get for much cheaper than buying and setting up gears, but it comes out of an automatic. The driveshaft on the auto has a flange compared to my standard which has a yoke. I really dont want to have to swap the flange to the yoke as I would pretty much be setting up the gears anyway to set the pinion preload (or I could guesstimate, but id rather not), and may as well just get new gears at that point.
It "looks" like the auto is using 1310 vs the standard using 1330 ujoints (I could also be wrong).
Now question before I go and buy this, is this worth it? Should I get a different flange plate to mate up to my ujoint size, or should I get one of those 1310 to 1330 conversion ujoints, or should I just pull the pinion nut and swap the flange to the yoke?
