Today, I took my libby out for a drive, and on the way to the woods "Thank god" I hit a bump, when i hit the bump, the jeep sounded like it went into neutral, i let off the gas, hit it again and it took off, I would think transmission slipping, HOWEVER, I can shift to 1,2,D,N,R "Kinda" it will not go into park at all, when it shows park its in reverse, when it shows neutral it Drives, but will not shift gears, like its in 2nd, and then if I go to 2, or 1, its the same as in drive. I checked the linkage under the car, and its still connected, even moved the shifter and the linkage moves. It does however feel that when I try to put it in park something is binding almost. Now that I have got it home and turned it off, since it will not go into park, I can not start it. :/ Anyone have any Idea's on where I should start.
*Edit, Thought I would add, it has 0 codes thrown.
Thank you
Thank you
