4.10's and 245/75
KJJosh
Northern VA
So a little about my rig.
It an 07 with full OEM skids, Frankenlift 2, JBA 4.5 Arms, ARB with Warn M8000, and duratrac load C tires.
Before the swap to 4.10's the ****** would have to down shift to make it up any sort of hill (I live outside DC). When down shifting the RPM's would go up to 3500 and stay there until I was able to top the hill. I had to drive with O\D off to insure it would stay in gear and not down shift. Now that the 4.10's are installed I'm able to cruise at 70-75 without the down shift. From the looks of it I'm back to 20mpg!!!
For those of you that say they dont need 4.10's when running 265/75 your crazy!!! I'm running a 245/75 and needed it!!!! Would I do it again???? Heck yes!!!!!! I will report back after the gears are broke in.
ShafferNY
Ticonderoga, NY
After driving my girlfriend's '06 with the 42rle transmission and my '03 with the 45rfe, I can't imagine hers with larger tires. It just doesn't have the bottom end torque my '03 does. The transmission seems geared too high.
J-Thompson
just south of doucheville
it is
the 45 has a 3 to 1 first and Reverse
the 42 is like 2.5 ,HUGE difference
Jo6pak
Left coast of WI
How do I know what trans my jeep has? Is it per year, or something else?
Yep Tom and myself keep saying it but no one would listen.Those gears do make a work of difference.
Atrus
Metro Detroit, MI
I'll have to remember this if/when I get 245/75's. If it helps driveability and MPG, then it makes sense to do it. No, the MPG gain may not totally justify the cost, but that plus driveability makes a strong case :D
