245/70/16 All Terrains
JayPee7986
FL
So I own a 2003 Jeep Liberty Renegade Edition and am in the market for new tires. I found some nice all terrains that are 245/70 in size. I've read a few thing that look like they'll fit without having to lift the Jeep. Was wondering if anyone knew for sure whether or not they'll actually fit in the wheel well without a huge amount of rubbing. Any help would be GREATLY APPRECIATED. Thanks in advance guys.
turblediesel
memberable
Alaska
That's what I put on mine. No lift, no rubbing. A little bit of understeer on hard pack snow roads but not bad.
Jo6pak
Left coast of WI
Mostly depends on the condition of your suspension. If the front has sagged much, they will likely rub.
Only way to know for sure is to fit them. Might need to do the pinch welds. And hell, it might give you the excuse you need to install a lift:icon_razz:
CzarKJ
Townsend, MA
If not lifting atleast do a clevis lift before you align to minimize rubbing. Might have to massage some plastic as well.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Measure from middle of the wheel to bottom of the flare , should be 19 inches, if not they will rub
