225/75R16 replace with 225/65R17?
tonyiiiafl
Found these. I tried 225/75R15 an wouldn't clear the frt calipers. So compared these 17's to the stock 16's. Thoughts? A tad slower speed at 65, however it will be a majority city car, very little highway use.
Current Tire Size: / 225/75R16
New Tire Size: / 225/65R17
Side by side Overlay
225/75-16225/65-17Difference
Diameter inches (mm)29.29 (743.9)28.52 (724.3)-0.77 (-19.6) -2.6%
Width inches (mm)8.86 (225)8.86 (225)0 (0) 0%
Circum. inches (mm)92.01 (2337.03)89.58 (2275.46)-2.42 (-61.58) -2.6%
Sidewall Height inches (mm)6.64 (168.75)5.76 (146.25)-0.89 (-22.5) -13.3%
Revolutions per mile (km)688.63 (427.89)707.26 (439.47)18.63 (11.58) 2.7%
Forum embed code
Speedometer Difference​
Speedo ReadingActual Speed
20 mph (32.19 km/h)19.47 mph (31.34 km/h)
25 mph (40.23 km/h)24.34 mph (39.17 km/h)
30 mph (48.28 km/h)29.21 mph (47.01 km/h)
35 mph (56.33 km/h)34.08 mph (54.84 km/h)
40 mph (64.37 km/h)38.95 mph (62.68 km/h)
45 mph (72.42 km/h)43.81 mph (70.51 km/h)
50 mph (80.47 km/h)48.68 mph (78.35 km/h)
55 mph (88.51 km/h)53.55 mph (86.18 km/h)
60 mph (96.56 km/h)58.42 mph (94.02 km/h)
65 mph (104.61 km/h)63.29 mph (101.85 km/h)
70 mph (112.65 km/h)68.16 mph (109.69 km/h)
75 mph (120.7 km/h)73.02 mph (117.52 km/h)
80 mph (128.75 km/h)77.89 mph (125.36 km/h)
85 mph (136.79 km/h)82.76 mph (133.19 km/h)
90 mph (144.84 km/h)87.63 mph (141.03 km/h)
95 mph (152.89 km/h)92.5 mph (148.86 km/h)
100 mph (160.93 km/h)97.37 mph (156.69 km/h)
Are they off a compass or patriot? The spigot on a KJ is bigger than the hole in the centre of the alloy so will need machining out to fit.
tonyiiiafl
A Patriot. So all should line up. I don’t need another set of useless tires lying around
tonyiiiafl
Are they off a compass or patriot? The spigot on a KJ is bigger than the hole in the Centre of the alloy so will need machining out to fit.
Well, i errored. I have a LIBERTY and these were from a Patriot! So, the center hole was 67.1MM and mine was 71.5! NO fit, SO, I made a jig to attach to my die grinder and ground off the inside ridge, which gave me 70MM. Then using the jig I as able to grind a perfect circle out to 72.5 MM. The larger hole was for my comfort that when the wheel went on, it would be centered by the lug bolts. Worked perfectly, and those 17's are smooth and quiet!
yesiam 1970
I hv men look at me like i rode the short bus when i tell them that my 03 Jeep Liberty has 17" tires (235/65R17), but the rims are original stock 16". Says right here in chart that they are compatible, but they still say it's not right.
Overlander BC
I have 235/65R17 on my 2006 on the factory Jeep wheels. It's a Limited. There isn't much room for mode rubber when I turn the front wheels. But that is factory tire wheel size
eagle1one
Hi, I own a Liberty 05 and it has 16 inch rims on and last fall I went to a tire and rim store to get some winter tires and this is what they sold me.
235/70 R16 106t
eagle1one
Sorry about that must have touched something on my cell.
235/70 R16 106T
If this helps you.
