2010 Jeep Liberty brake locking up
Pappypaul
My 2010 Jeep Liberty has had 2 episodes where the brakes locked up after starting off from a stop on a slight grade. Has anyone else had this happen and does anyone have any advice. i have not had any lights or warnings both times. Thanks so much for any help!!
Just hangin' out.
Have a good solid look at your parking brakes. Quite a few of us have had issues with stuck/sticky pinion hinges. You’ll have to pull the wheel, caliper and rotor drum. The linkage is at the TDC. You may also find like I did the the small screws that hold the backing plate on broke off.
