2007 Jeep Liberty overheating. Need some help
Discussion in 'KJ General Discussion' started by BrendenKJ, Sep 21, 2019.
  1. BrendenKJ
    BrendenKJ New Member
    Sep 21, 2019
    alright, so I was driving on the expressway and my car overheated and lost all coolant and popped a engine light. Ran the light it was a coolant temp sensor. Replaced that it still overheats no engine light not sure what the issue is. Any ideas? Or tips to help diagnose?
    2007 Jeep Liberty Sport 3.7 V6
  2. Byron
    Byron Member
    33
    Jul 13, 2019
    Bad thermostat maybe?
    Is the electric fan working?
  3. BrendenKJ
    Sep 21, 2019
    The fan is working. The thermostat is what I was suspecting too. Just wanted some opinions
  4. tommudd
    tommudd Moderator Staff Member Moderator
    17,781
    415
    Since you ran it hot, I'd do thermostat, upper and lower hoses
    then check make sure water pump is OK
    Make sure you use HOAT coolant only and use the bleed valve/ plug right behind the upper rad hose
    check radiator at the left upper side to make sure it is not leaking
  5. BrendenKJ
    Sep 21, 2019
    Alright thank you I will order a thermostat tonight. How would I go about checking if my water pump needs to be replaced. I looked around it and didn’t see any leaking.
  6. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,042
    363
    Only buy a Mopar thermostat.
    [​IMG]
