Thank you. I’m gunna give them a check after work if not tomorrow morning. Hopefully can get this figured out so I don’t have to just start replacing random parts.I had to replace sway bar bushing on my jeep it was making a similar noise to yours. Almost sounds like something is out of grease. I'd check them and ball joints
I’ve attached a video. It happens mostly when I turn the wheel. On some other occasions too. Thanks in advance.
I think his is a ball joint too.Front end components on the Liberty are pretty easy to isolate and inspect for condition. I would check it out sooner than later though. I had a front lower ball joint break and thankfully i was going pretty slow when it happened. Could have been a whole lot more serious ending if it had been at highway speeds. Ball joints will generally give you a little bit of advance warning before they fail in most cases. Mine had started having a slight kick back in the steering a few weeks before it broke. I just didn't recognize it at the time. No noise in the steering though on mine. I've since replaced every ball joint on the front end and the upper ball joint/ control arm on the rear suspension, as well as inner and outer tie rods.
