2006 Jeep Liberty fuel mystery
mbrossmale
I have a 2006 Jeep Liberty 65th anniversary 3.7L Automatic. I started the car and forgot something turned it off went to start it again and it wouldn’t turnover. After some checking we decided it was the fuel pump because gas wouldn’t spray from the hose. We replaced that and it wouldn’t start or when it did it idled very rough. When you pushed the gas it stalled. Took the fuel pump out got another same problem. Replaced the map sensor, intake sensor, and camshaft. I bought a used ECM. Nothing has changed. Now it’s giving me a no bus code and saying the gas is too lean. It’s at my mechanic and he’s stumped. My family is telling me to junk it. I’ve been three months without my Jeep. Please help.
Welcome to the forums.
Using a fuel pressure tester, what is the current psi reading when key is turned on?
Spark plugs= do a compression test on each cylinder, what are the psi reading on each cylinder?
Ensure correct plugs are installed and gapped correctly.
Use:
2006 Factory Service Manual - http://www.colorado4wheel.com/manuals/Jeep/KJ/2006-KJ-SM.pdf
mbrossmale
We did rent a fuel sensor tester and it was fine (according to my husband) and the spark plugs are all in good shape he tested those as well. The mechanic says the fuel injector all opens and closes properly so it couldn’t be that right?
Knowing the exact fuel psi reading would be helpful.
Also knowing the exact compression readings from each of the cylinders and plug type as above is good helpful info.
If the compression is not within specifications, it may not start.
