2006 Jeep Liberty 3.7
Discussion in 'KJ General Discussion' started by Brawkzlit, Feb 28, 2020.
  1. Brawkzlit
    Brawkzlit New Member
    Feb 28, 2020
    Hey guys really searching for some help, the other day I started my KJ, and it had this loud ticking noise when I was to accelerate it was get faster. Anyway I changed oil and added lucus oil to too make it thicker, well there is still a tick and Just lookin gun for some advice, I’m pretty mechanically inclines so just looking for some help.
  2. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    6,767
    265
    Welcome.
    Sounds like an engine ticking noise, valve train tick .??
    A mechanical stethoscope may help to pinpoint left or right side etc.
    May have to pull valve cover (s)
    to inspect rockers, or one loose ?
    You could pull the accessory serpentine belt for a few moments, to eliminate accessory noises.
    Brawkzlit likes this.
  3. Brawkzlit
    Feb 28, 2020
    Yeah I also used at stethoscope, and found out it’s on the passenger side, only 128000 on it. I checked to see if it was an exhaust leak but puttin In the new oil kinda proved that. If I pull the vale cover off how would I be able pinpoint what’s bad
    LibertyTC likes this.
  4. tommudd
    tommudd Moderator Staff Member Moderator
    17,568
    328
    Making oil thicker will not help and many times make it worse
    If you pull the cover you should be able to tell if a rocker is loose or getting ready to fall off
    ltd02 likes this.
  5. Brawkzlit
    Feb 28, 2020
    Oops lol. Being that they’re hydraulic lifter I thought maybe if the was a weak lift it would keep it from Ticken like it was. Alright I’ll give it a look here a let you know what’s up, Bronson gym my fingers it’s not a crank bearing or something down there lol
  6. jeeper03
    jeeper03 Full Access Member
    117
    Sep 27, 2015
    warrenton Va
    I would change all the lifters in it. Honestly not that bad of a job if you have the tools and I’ve seen to many fail right around 100k. Don’t end up like this guy, just put a new engine in his at work last week.
    Brawkzlit, ltd02 and LibertyTC like this.
  7. Brawkzlit
    Feb 28, 2020
    Yeah I’m going to see, and replace the gaskets and stuff. It kinda stops ticking when she get warmed up. Thanks for the advice guys!
  8. tommudd
    17,568
    328
    Have a customers 05 that has a slight tick in it till it warms up. At 25-30 degrees it does it for about 5 minutes or less
    He is of the type if its still running don't touch it LOL
    Love to get in there now and replace rockers/lifters esp since I have a set sitting in the shop
    ltd02, Shane Giggie and LibertyTC like this.
  9. Shane Giggie
    Shane Giggie Full Access Member
    83
    Nov 26, 2019
    My 06 ticks a little too until it gets warmed up then its perfect. Mine has 240,000kms not sure what that is in miles.
  10. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,556
    117
    Yeah, that's about 150k. That's about when I had a few weak ones in my 02. Actually had the #2 exhaust fall of twice. The second time I replaced several of the lifter/lash adjuster on that side and no more problems.
  11. Brawkzlit
    Feb 28, 2020
    The next day it had a loud tick, changed oil tick gone when warms up. I’m having someone diagnose it Monday, then I’m going to fix it
    ltd02 likes this.
  12. Brawkzlit
    Feb 28, 2020
    I just wanna make sure Ik what it is before I tear it apart, if it’s like a cam bearing then I’m goin to probably have to get some stuff Cause I don’t have cherry pick or engine stand
    ltd02 likes this.
  13. Brawkzlit
    Feb 28, 2020
    Yeah I believe that’s like 150
  14. Brawkzlit
    Feb 28, 2020
    In miles
