jagster936
- Joined
- Jul 19, 2024
- Messages
- 2
- Reaction score
- 0
I have read around and can't seem to figure this one out. If this is true, ~0V is full tank, ~8V is empty. The behavior of my CRD is as follows:
Sometimes works normally. When go over rough spots it can change. The SPAN of the range changes. So like it will go from 1/2 tank down to zero. It still seems linear. So for example it will go from 1/2 tank to zero, which is really full tank to half tank. Then the light comes on etc. A partial short on the output signal would indicate more FULL then more EMPTY. So what the heck kind of failure can this be? The linearity of it isn't changing, just the range, E-1/2 tank becomes what is in reality, 1/2 tank to FULL tank. I have been scratching head for months and years and can't seem to figure out how any kind of rubbing wire can cause this, or any other failure for that matter. A sticking float wouldn't behave this way would it? It would stay in one spot then jump or do something different, not what I'm experiencing. Any ideas? Thanks
