2004 Liberty Sunroof
Georgia04kj
The plastic part of my Sunroof slider got chewed up. I had to cut it out. My question is how do you get the new slider installed on the track?
yesiam 1970
Mine broke too...well the plastic piece that lifts window up n into place. I went to pick n pull n got one. But I'm ADD n typically never finish projects, so I was too scared to actually change it. Just glad I got back into place, and sealed the edges on roof so wldnt leak. Except the lwak kept happening ...rite into my door panels. So read on here it was prob clogged drain holes on front corners of sunroof that drains down A frame and on to ground. Took me 2 years to realize it was actually the worn out window seals? That snaps into bottom of window frame where window slides up n down. Supposed to have fuzziness to keep water out. They r expensive new, so back to pick n pull
The doors should drain, there are holes in the inside lower, probably blocked with dirt/ rust or cavity wax
