2004 Liberty 3.7L high fuel rail pressure
04Liberty#!
Thank you
yes, probably not related, except for running the engine hard to test.
Should start a new thread for this?
Once resolved I can come back and finish this thread?
1st thing I thought I try, is, switch plug and coils on #1 and #2 cylinder to rule them out.
Plug gap on cylinder 2 was ~0.0375". I understand it should be 0.04. Close enough?
New plugs are Iridium BK6REIX-11, Old Plugs were Champion 3318.
I'm learning not to trust online lower cost parts.
Might be a week before I can get back into this.
Regards
Intermechanico
Port Moody B.C.
Thank you
Regards
I’d leave it all here in one place. When we eventually get to the bottom of it, the relationship between failure modes will be helpful for others.
Good luck, keep your chin up.
04Liberty#!
Will do. Thanks!
Cleared P0302 codes.
Also cleared a P0113 (Intake Air Temp Sensor 1 Circuit High Input)
Swapped Coil and Plug from Cylinder 1 and 2.
Ran it with low reves just long enough, to get Engine light.
DTC P0302 indicates issue remains with Cylinder 2.
I will pick up an extension for compression tester and report back.
04Liberty#!
Update:
I: pulled the fuel Pump fuse and bleed off fuel rail pressure.
Removed #2 plug and coil.
Threaded in compression gauge assembly into #2 spark plug socket
Cranked engine; Pressure gauge moving between 120 and 150psi
When I stopped pressure held at 140Psi
Relieved pressure. Repeated and got same results.
I: Removed compression gauge assembly.
put a little oil in cylinder 2 through the spark plug port.
Reinserted compression gauge assembly into cylinder 2 spark plug port.
Cranked engine; Pressure moving between 140 and 150 psi
Cranked again and pressure moving between 150 and 170 psi.
When I stopped pressure held at 170psi
I: relieved pressure, did multiple very short cranks, until cylinder 2 pressure jumped.
removed compression gauge assembly, inserted long slender rod into spark plug port.
Marked rod where it lined up with dip stick.
With socket and rachet rotated crank shaft from under front of liberty,
a little at a time in both directions checking rod mark at dip stick to find TDC of Cylinder 2.
Pulled rod. Removed Shrader valve and gauge from compression gauge assembly.
Installed male air hose connector into compression gauge assembly hose, in place of gauge with on hand adapters.
Installed the modified assembly into Cylinder 2 spark plug port. Set shop air pressure regulator to 120psi, shut shop air valve.
connect shop air hose to modified assembly, slowly opened shop air valve.
I had a lot of air leaking from the #2 spark plug port and pressure stayed at approximately 100psi.
When I shut off the shop air valve pressure fell slowly to 30psi. Then stayed at 30 psi.
I then released remaining pressure, reconnected assembly to Cylinder 2 spark plug port and opened shop air valve.
Connection at spark plug port seamed good no leaks no sounds. Pressure held at 120 psi.
I listened to; exhaust, radiator fill port, head/valve cover, air intake, etc. and did not hear or sense any leaks.
When I shut the shop air valve pressure fell slowly to 30psi and stayed there.
I think:
170psi compression is in range, and # 2 rings are ok but should test all cylinders to compare.
Bleed test did not indicate other issue. Tapping noise at #2 makes suggested removing valve cover to inspect #2 rocker arms a good next step.
Thoughts?
Intermechanico
Port Moody B.C.
Update:
I think:
Thoughts?
Yep. Let’s get eyes on those rockers.
04Liberty#!
UPDATE 20261016:
You called it!
Got the Bank 2 valve cover off.
Noticed exposed push rod on Cylinder 2
Checked under the cam shaft and there was the loose rocker arm.
Man! that could have caused some damage. But everything looks okay.
See attached:
Thank you!!
So now how do I get that back under the cam shaft and over the rods properly?
  • Update 20261016.pdf
04Liberty#!
Update 20261016B:
I watched a couple videos online and:
1.) Rotated the drive shaft underneath front of engine with 13/16 socket and ratchet, Until Cylinder 2 rear cam was straight up.
2.) Positioned rocker arm assembly under the cam shaft with valve end on top of valve and lifter end lined up with lifter as far forward as possible.
3.) Then with screwdriver as a lever and valve compartment wall as a fulcrum pushed the rocker assembly forward until lifter snaps into center of rocker arm indentation.
It snapped in and seems tightly positioned between cam, lifter and valve stem.
I'm off to get a valve cover gasket kit and will report after everything is back together and I run the engine again.
04Liberty#!
Update: 20261027
Ran her at low-speed low rpm on the property for a few days without codes.
Put her on the road today 0 to 85mph. Accelerating slow and fast. Mostly between 40 and 60 mph.
Responsiveness was slow and a little rough. Engine light did not come on.
But when I checked I had a DTC P0159, O2 Circuit Response Slow (B2S2).
After that run I got the attached data with; key on and engine off.
Then, Live Data, at idle in neutral: O2 B2S2 = .92 to .94 V (99.2%)
Live Data, at high revs in neutral: O2 B2S2= .80 to .94 V (99.2%)
I'm thinking the DriveBolt B2S2 O2 sensor (although new) is not a proper match, Like the B1S1 and B2S1 sensors that I changed out to Mopar OEM sensors.
But odd B1S2 does not seem to have an issue. Could it be wiring or exhaust leak on passenger side?
Thoughts?
  • UPDATE 20261027.pdf
04Liberty#!
Update: 20261030
I Pulled DriveBolt OXS251101 O2 sensor @ B2S2 to test it.
Wire colors match the old MOPAR 56028996AA and 56028994AA
But do not match info I found on-line.
(see attached, '2004 Jeep Liberty 3.7L PCM & O2 pin #'s.PDF')
Test Results: (sensor plug port 1 to port 2, white wire to white wire):
DriveBolt OXS251101 => 8.7 ohms.
Old Mopar 56028996AA => 4.5 Ohms
Online sources give 5 to 7 ohms as good range. OEM Range?
I installed the old MOPAR 56028996AA @ B2S2
and left new DriveBolt OX251101 @ B1S2.
Live data from drive test is attached. ('B2S2 2nd test.PDF')
Test drive was in neutral with mild revving.
To me it looks like both downstream O2 sensors are working but are very different.
Which is better or more normal? Should they be similar?
Does this indicate a difference in CAT performance and is that an issue if within range?
Thoughts?
  • 2004 Jeep Liberty 3.7L PCM & O2 plug pin #'s.pdf
  • B2S2 2nd Test.pdf
