2002 Jeep Liberty air intake-resonator to ?
A77larsen
I do not know what that piece is called from resonator but there is a “spout”?? Coming from it that ***** in air. If I put my finger in it the Jeep dies. What should be there?
A77larsen
I found another pic on here but I need to know where the other end is attached to
Welcome to the forums.
Under hood on your 2002 rad support is there a hose routing sticker ?
I found this 2002 photo online. Hope this may help. Others may chime in to help as well.
*Moved to the KJ General Discussion section.
Aceofspades
Buffalo
If you follow that does it go to a hard plastic line ? If so that might be the EVAP tie in. The EVAP is by the battery.
basically work backwards from the EVAP solenoid by battery you should find the missing hose somewhere unless someone took it off and it didn’t fall off
