2 DIN Chrome/silver bezel?
Discussion in 'Electronics' started by GitEmSteveDave, Jun 4, 2018.
  1. GitEmSteveDave
    GitEmSteveDave Full Access Member
    337
    74
    Feb 23, 2018
    Howell
    I have a 03 Renegade and my dash panel is Chrome/Silver. I want to get a replacement stereo, but what do I go for? Everything 2din for a liberty is black, and that would clash with all the other bezel panels. Are there liberty radios that don't need a panel?
  2. jeeplib05
    jeeplib05 Full Access Member
    851
    Jan 7, 2016
    Ohio
    Silver paint :happy175:
    Kidding, but I've seen some radios that are silver, but more of a brushed or stainless look at Best Buy
  3. nbas
    nbas Full Access Member
    75
    Jul 21, 2017
    Greece
    This is the main reason I haven't upgraded my Head Unit! I searched all over internet for a 2DIN silver dash panel with no luck...
  4. GitEmSteveDave
    337
    74
    Feb 23, 2018
    Howell
    Maybe JeepLib05 has a point. If you rattle canned the black 2din replacement panel and the already silver one on around the shifter at the same time with the same can, they would match. And since nothing else is the same silver, it would appear stock if there were no big runs or defects in the paint job.
  5. nbas
    75
    Jul 21, 2017
    Greece
    It has silver on the doors also and steering wheel. I like the finish and it seems strange that there is no such 2DIN dash panel. :emotions34:
  6. GitEmSteveDave
    337
    74
    Feb 23, 2018
    Howell
    I think those are far enough away from the mass of silver in the center that a slight difference wouldn't matter.
    I'm considering going to the local pick and pull and seeing if I can snag a shifter cover and trying it with a rattle can. Worse comes to worse, I'm out $10 for supplies. I need and excuse to go there to try to get a flipper pad for the liftgate glass anyway.
  7. Reaper13
    Reaper13 New Member
    Jan 21, 2020
    Jacksonville FL
    I swapped over to a double din and currently in the process of turning all the silver trim peices in my JK to black. Alreadyvrattle canned the shift bezel. Best thing to remember is the prep work.. clean scuff wipe prime.... if that comes out good then spray your color and maybe a coat or 2 of clear. I like using the duplicator paint match car paint.
