03 limited TCM help
Discussion in 'KJ General Discussion' started by Codad, May 11, 2019.
  1. Codad
    Codad New Member
    23
    Jan 25, 2019
    KY
    I was told that I needed a new TCM, my part number is P56044192AE. I can't find and others that end in AE, onlu AA, AD, AF and so on. Will those also work or do I have to have one that ends in AE?
  2. Billwill
    Billwill Full Access Member
    1,283
    45
    Nov 26, 2009
    White River, South Africa
    Those last two characters are the Revision number...using a higher revision number is always better as some improvements may have been made...so AF is better than AE.;)
  3. Codad
    Codad New Member
    23
    Jan 25, 2019
    KY
    Alright, thank you!
  4. Benji
    Benji New Member
    Monday
    Codad did u happen to put the different tcu in ur liberty? If so how did it work? I can't find one ending as either!
  5. Codad
    Codad New Member
    23
    Jan 25, 2019
    KY
    So was told the last letters were just revisions like AF was better than AE. I ended up getting one off eBay, part number: P56044192AF for pretty cheap. Took the old one off and put the new to me one on and everything went back to working fine.
  6. Benji
    Benji New Member
    Monday
    No check engine light or anything came on? So it was just like new again? This has been a pain in my butt. Thanks for ur help!
  7. 04Liberty
    04Liberty Full Access Member
    1,175
    Sep 14, 2006
    MD
    As long as the numbers and the second to last character are the same you're golden.
  8. Benji
    Benji New Member
    Monday
    P56044192 AE is my part number.
    So I need the same part number and the letter A to match?
  9. 04Liberty
    1,175
    Sep 14, 2006
    MD
    Yep. As stated, the later you can find the second letter the better (like if you can find an "AF").
  10. Benji
    Benji New Member
    Monday
    Gotcha! I wasn't aware that the AF had the same numbers as mine. Thanks!
