'03 KJ lift question
tylerlsch
Denver, CO
Hello all! I have an '03 Freedom Ed, and want to lift it only enough to fit some "real" tires, i.e. 245/70/r17's. However, I don't want to put on some plastic or rubber pucks that will mess with my suspension long term. The car will rarely see the off-road, and I am concerned about lifting it 2.5" or 3" with a Frankenlift or Rusty's so as to change its cornering or high-speed handling. Basically, I just want to make it 1" or 1.5" higher with a little more travel.
Any great suggestions? What about the OME lift kit? Or some other hybrid set up?
Any comments welcome, and thanks to all who help...
-tylerlsch
priell3
Check out this 2" lift from 4WD Hardware. It's conservative and what I have on my KJ for the occasional off-roading I do. No pucks, greatly improved ride. 2" Liberty Lift
Here is a pic of mine along with another KJ with the same lift.
My black KJ has 245/70/16 Bridgestone Dueler A/Ts, the Garnet KJ has 245/75/16 Goodyear MT/Rs.
More pics of mine with the lift and tires on this page:
http://www.cardomain.com/ride/338447/3
fouros
Gold Coast Australia
OME is good
it is THE kit we have in Australia, the ride is Awesome, and you can set it up if you want to add a bull bar or a winch with different spring rates
before
after
Eddo
USA
-tylerlsch
I have the complete medium duty OME front strut assemblies for sale. Completely assembled - no spring compressor necessary, just bolt right in. I replaced it with the Frankenlift because I wanted heavier springs and max height. I also have the OME rear shock if you are intrested. All you would need would be the rear springs.
dnm45227
Midwest
I don't know if this should be here or in the "lift disc." forum, but here goes. If I have a pre-lowered '02, isn't it like I already have about a 2" "lift kit"?
Eddo
USA
7/8" difference in the front and 3/4" in the rear
dnm45227
Midwest
fouros said:
Nahh you only have 3/4" to 1" over us lowered KJ's
I spend way too much time here. When I read you response. I "heard" an accent.
Thanks for the ressponse guys!
dnm45227
Midwest
I spend way too much time here. When I read your response. I "heard" an accent.
Thanks for the response guys!
fouros
I know what you mean
oh oh oh
If your hearing the accent i should have said
Nahhh MATE
just to OZ it up for you \:D/
