03 KJ Air in power steering, no leak, no power
Steven Renich
I have an 03 KJ 3.7 project
I just replaced the engine and a leaky power steering pressure side hose. The pump and hose were disconnected and sitting in the garage for a couple of months while I messed with the engine.
When I put everything back together, I tried to burp the power steering and I can't get the air out. I put the front end up and turned the wheel (per the Jeep manual). I also used a vacuum pump. The fluid level doesn't drop and there are no leaks, but there are always more bubbles. And there is no power assist.
I also pressure tested the system with a hand pump. No leaks found.
I could replace the pump with a reman unit, or I could replace the reservoir o-ring and the return line. The return line on the original is integral to the cooler, but that assembly is pricey. Can I just cut the hose crimps and replace the hoses?
Any suggestions would be helpful particularly in diagnosis before I start throwing parts at it.
Definitely sounds like air is still entering the system somewhere. When front wheels were off the ground, did you try lock to lock like 25 times?
Are you using ATF+4 in the PS unit?
I wouldn't be cutting the return line hose.
Steven Renich
Oops - I just noticed that I posted this in the KK General Discussion, It should be in the KJ forum. Sorry.
I tried lock to lock many more than 25 times. I am using power steering fluid.
From the Jeep manual "CAUTION: Use MOPAR Power Steering Fluid or equivalent. Do not use automatic transmission fluid
and do not overfill."
I would really like to figure out where the air is getting in.
No worries, moved now to KJ Gen Discussion.
I think the next move is to install a new pump.
Billwill
White River, South Africa
From the Jeep manual "CAUTION: Use MOPAR Power Steering Fluid or equivalent. Do not use automatic transmission fluid and do not overfill." I would really like to figure out where the air is getting in.[/QUOTE said:
The 2002 KJ manuals state that MOPAR Power Steering fluid must be used.
Around 2003 a TSB was issued that KJs need to be taken to the Dealers to have the Mopar Fluid drained, flushed out and replaced with ATF +4 "Do not mix the two different fluids"
I chose to keep my 2002 Export CRD on the Mopar Power Steering Fluid as I do not trust the Local Dealers to get anything right...every year or so I suck out all the fluid in the Resevoir with a large syringe and fill it up again with Mopar fluid which is virtually clear in color but darkens to a honey color with age.
The ATF +4 fluid is a light red color.
So is it possible that if there was a previous owner of your KJ that ATF+4 was used and maybe you have added Mopar Fluid?o_O
