Atrus
I’m not sure that I’ll be able to describe this well, but I am going to give it a try. Hopefully someone has experienced this.
I notice a “POP” when I first take off in the KJ, typically in the morning. Seems to be coming from the front, and probably 75% of the time it seems to be in the middle of the front suspension or towards the passenger side. Sometimes it sounds to be from the driver side.
It’s not a “CLUNK” like metal shifting on metal or anything. It’s kind of a medium tone (not high pitched or low pitched) and is just a quick “POP”…for some reason it really reminds me of something suspension related, like a spring or strut making noise. I know that makes no sense as our front shocks/springs are static and don’t pivot. I almost thought it was brakes – like a pad sticking to the rotor, but I’ve since changed all of the pads (due to wear, not the noise) and it still does it.
I believe it's done this when the wheel is straight as I am taking off, but it definitely does it religiously when I am turning slightly when I first take off. Also doesn't seem to matter if I am in 2wd or 4wd. It seems to do this only when I first take off after it’s sat for a while. I’ll hear it and try to replicate and it it will not make the noise again. It is almost everytime I take off in the morning (like 99.9% consistent) or when leaving work. I don’t get any unusual noises when driving, no banging or clunking in the suspension at all. I park in a deck on the weekdays and go over no less than 6 speed bumps at low and moderate (5mph to 15 mph) and don’t hear anything out of the ordinary.
Any ideas? I plan to check the LBJ’s tonight when I get home.
