Atrus
OK, no pics yet, so feel free to yell Camera batteries are shot, and I didn't feel like postponing at all to go to the store for some.
So, the install went OK. I started with the driver's side, which took me forever to figure it all out - how to get the clevis off, etc etc. The passenger side took about 1/4 the time.
Let me say that it was a TON of fun using the rented spring compressors and hand tools. My forearms got a nice workout today.
Tip for removing the clevis fork - pull clamp bolt out...thread it in backwards (start it in the side with threads)...put in a box end wrench or a good size washer into the slot, and tighten the bolt against it. It'll spread the clevis open nicely.
Beginning specs:
Driver Front: 12.25" to pinch weld, 31.5" to bottom of flare.
Passenger Front: 12.50" to pinch weld, 32" to bottom of flare.
Driver Rear: 32.25" to center of flare
Passenger Rear: 32.5" to center of flare.
Ending specs:
Driver Front: 14" to pinch weld, 33.5" to bottom of flare
Passenger Front: 14.24" to pinch weld, 34" to bottom of flare.
Driver Rear: TBD
Passenger Rear: TBD
I'll edit this post as I continue on. I am done for the night, I am about to take it out and see if it affected suspension feel significantly. If I don't like it, I'll just pull it out.
Other thing I noticed is I was bouncing the front end and it gets that poly "squishy" noise, like tires turning on a painted floor. I am going to see how noticeable it is. Hopefully it's not annoying. I can't remember if there was any noise stock, I'll stop by a dealer tomorrow and bounce the front end on one.
So, that's it for tonight. Will update more tomorrow. Initial impressions are that I love how the front looks. I definitely need to throw an isolator or two into the rear as the front is noticeably higher. Ball joints don't even come close to contact with the spring - a good .5"-.75" out. I can fit my fingers in between them.
Updated info:
Well, I re-measured everything today in the driveway (so, I suppose it could be slightly off level). I have the following:
Driver Front - 33" to flare, 14" to pinch weld
Passenger Front - 33" to flare, 14" to pinch weld
Driver rear - 33" to flare
Passenger rear - 34" to flare.
That's only the 3/4" spacer added to the front, and 2 extra upper isolators on the rear (total of 3 per side). I am going to have to look into the one corner, it's noticeably higher. Not sure what the deal is there.
Like I mentioned - little bit of noise from the front on a decent bump, none noticed on smaller bumps. Ride quality seems to be the exact same to me. It looks darn level, if not having a very slight forward rake.
Sorry for the dark pics, it's overcast here. If people want to see, I can get better ones later. There definitely is a noticeable difference:
For comparison, here is it stock in the same location:
Beginning specs:
Ending specs:
Driver Rear: TBD
Passenger Rear: TBD
Updated info:
