Kj Dtc List
gmctd
Texas
KJ DTC INDEX V6 and 2.8L Diesel
Description
B10B3-VISCOUS/CABIN HEATER RELAY CONTROL OPEN CIRCUIT .
C100A–LEFT FRONT WHEEL SPEED SENSOR CIRCUIT.
C1011–LEFT FRONT WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE
C1014–LEFT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE
C1015–RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT.
C101C–RIGHT FRONT WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE.
C101F–RIGHT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE.
C1020–LEFT REAR WHEEL SPEED SENSOR CIRCUIT.
C1027–LEFT REAR WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE. .
C102A–LEFT REAR WHEEL SPEED COMPARATIVE PERFORMANCE.
C102B–RIGHT REAR WHEEL SPEED SENSOR CIRCUIT. .
C1032–RIGHT REAR WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE. .
C1035–RIGHT REAR WHEEL SPEED COMPARATIVE PERFORMANCE.
C1041–LEFT FRONT TONE WHEEL PERFORMANCE
C1042–RIGHT FRONT TONE WHEEL PERFORMANCE .
C1043–LEFT REAR TONE WHEEL PERFORMANCE .
C1044–RIGHT REAR TONE WHEEL PERFORMANCE . . .
C1046–LEFT FRONT WHEEL PRESSURE PHASE MONITORING .
C1047–RIGHT FRONT WHEEL PRESSURE PHASE MONITORING . .
C1048–LEFT REAR WHEEL PRESSURE PHASE MONITORING .
C1049–RIGHT REAR WHEEL PRESSURE PHASE MONITORING
C1073–ABS PUMP MOTOR CONTROL CIRCUIT. . .
C1078–TIRE REVOLUTIONS RANGE PERFORMANCE .
C107C–BRAKE PEDAL SWITCH 1/2 STUCK
C107D–BRAKE PEDAL SWITCH 1/2 CORRELATION.
C1210–G SENSOR INPUT CIRCUIT PERFORMANCE .
C1219–STEERING ANGLE SENSOR ERRATIC PERFORMANCE.
C121A–STEERING ANGLE SENSOR NOT INITIALIZED.
C121C–TORQUE REQUEST SIGNAL DENIED .
C121D–BRAKE PRESSURE SENSOR CIRCUIT.
C121E–BRAKE PRESSURE SENSOR COMPARATIVE PERFORMANCE .
C1231–DRIVE TEST: STEERING ANGLE SENSOR.
C1232–DRIVE TEST: PRESSURE SENSOR
C1234–DRIVE TEST: SENSOR CLUSTER INSTALLATION.
C1238-DRIVE TEST: UNSUCCESSFUL .
C1239–EMISSIONS ROLLS TEST ACTIVE
C123A–ESP SYSTEM SENSORS CALIBRATION.
C123B–ESP SYSTEM CONTROL TOO LONG
C123C–DYNAMICS SENSOR MOUNTING/INSTALLATION PERFORMANCE .
C123F–STEERING ANGLE SENSOR COMPARATIVE PERFORMANCE
C1240–STEERING ANGLE OVERTRAVEL PERFORMANCE. .
C1242–GSENSOR INPUT SIGNAL PERFORMANCE
C1243–G SENSOR NOT INITIALIZED
C2100–BATTERY VOLTAGE LOW
C2101–BATTERY VOLTAGE HIGH
C2111–SENSOR SUPPLY 1 VOLTAGE CIRCUIT LOW.
C2112–SENSOR SUPPLY 1 VOLTAGE CIRCUIT HIGH
C2114–DYNAMICS SENSOR SUPPLY VOLTAGE LOW.
C2115–DYNAMICS SENSOR SUPPLY VOLTAGE HIGH .
C2116–ABS PUMP MOTOR SUPPLY LOW VOLTAGE.
C2200–ANTI-LOCK BRAKE MODULE INTERNAL .
C2204–DYNAMICS SENSOR INTERNAL
C2205–STEERING ANGLE SENSOR INTERNAL
C2206–VEHICLE CONFIGURATION MISMATCH.
U0001–CAN C BUS
U0002–CAN C BUS OFF PERFORMANCE
U0100–LOST COMMUNICATION WITH ECM/PCM .
U0101–LOST COMMUNICATION WITH TCM .
U0121-LOST COMMUNICATION WITH ABS
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE .
U0125–LOST COMMUNICATION WITH DYNAMICS SENSOR
U0126–LOST COMMUNICATION WITH STEERING ANGLE SENSOR.
U0140-LOST COMMUNICATION WITH BODY CONTROL MODULE
U0146–LOST COMMUNICATION WITH CENTRAL GATEWAY .
U0155-LOST COMMUNICATION WITH CLUSTER.
U0168-LOST COMMUNICATION WITH SKIM/SKREEM (WCM).
U0401–IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM.
U0429–IMPLAUSIBLE DATA RECEIVED FROM SCM.
U1003–ESP CAN C BUS PERFORMANCE
U1104–CAN C BUS CRC PERFORMANCE
U110C-NO FUEL LEVEL BUS MESSAGE RECEIVED .
U110E-LOST AMBIENT TEMPERATURE MESSAGE .
U1110-LOST VEHICLE SPEED MESSAGE.
U1113-LOST A/C PRESSURE MESSAGE .
U1120-LOST WHEEL DISTANCE MESSAGE
U140E–IMPLAUSIBLE VEHICLE CONFIGURATION DATA RECEIVED .
U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED .
U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED .
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED.
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED.
U1501–IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ECM/PCM .
U1502–IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM TCM .
U1503–IMPLAUSIBLE MESSAGE DATALENGTH RECEIVED FROM FCM / BCM.
gmctd
Texas
Powertrain Diagnostics
B10b3-viscous/cabin Heater Relay Control Open Circuit .
P0016–crankshaft / Camshaft Timing Misalignment.
P0031-o2 Sensor 1/1 Heater Circuit Low.
P0032-o2 Sensor 1/1 Heater Circuit High.
P0037-o2 Sensor 1/2 Heater Circuit Low.
P0038-o2 Sensor 1/2 Heater Circuit High.
P0045-boost Pressure Solenoid Excessive Current.
P0045-boost Pressure Solenoid Open Circuit .
P0047-turbocharger Boost Pressure Solenoid Short To Ground.
P0048-turbocharger Boost Controlcircuit Short Circuit .
P0051-o2 Sensor 2/1 Heater Circuit Low.
P0052-o2 Sensor 2/1 Heater Circuit High.
P0057-o2 Sensor 2/2 Heater Circui Low.
P0058-o2 Sensor 2/2 Heater Circuit High.
P0068-manifold Pressure/throttle Position Correlation .
P0069-BOOST KEY-ON RATIONALITY
P0070-ambient Air Temperature Signal Voltage Too High .
P0070-ambient Air Temperature Signal Voltage Too Low
P0071-ambient Air Temperature Sensor Performance .
P0072-ambient Air Temperature Sensor Circuit Low.
P0073–ambient Air Temperatur Sensor Circuit High
P0087-fuel Rail Pressure Malfunction Pressure Too Low.
P0088-fuel Rail Pressure Too High .
P0089-fuel Pressure 1 Control Performance
P0090-fuel Quantity Solenoid Open Circuit
P0091-fuel Quantity Solenoid Short To Ground .
P0092-fuel Quantity Solenoid Short Circuit.
P0093 - Fuel Rail Pressure Malfunction Positive Pressure Deviation.
P009a-intake Air Temp/ Ambient Air Temp Plausibility .
P0100-maf Sensor Signal Voltage Too High
P0100-maf Sensor Signal Voltage Too Low .
P0101-maf Sensor Signal Negative Deviation.
P0101-maf Sensor Signal Positive Deviation.
P0105-inlet Pressure Sensor Signal Plausibility.
P0105-inlet Pressure Sensor Signal Voltage Too High
P0105-inlet Pressure Sensor Signal Voltage Too Low
P0107-manifold Absolute Pressure Sensor Circuit Low.
P0108-manifold Absolute Pressure Sensor Circuit High.
P0110-intake Air Temp Sensor Signal Voltage Too High
P0110-intake Air Temp Sensor Signal Voltage Too Low .
P0111-intake Air Temperature Sensor Rationality.
P0112-intake Air Temperature Sensor Circuit Low.
P0113-intake Air Temperature Sensor Circuit High.
P0115-engine Coolant Temp Sensor Signal Voltage Too High .
P0115-engine Coolant Temp Sensor Signal Voltage Too Low
P0116–engine Coolant Temperature Sensor Circuit Performance.
P0117-engine Coolant Temperature Sensor Circuit Low.
P0118-engine Coolant Temperature Sensor Circuit High.
P0122-throttle Position Sensor 1 Circuit Low .
P0123-throttle Position Sensor 1 Circuit High
P0125-insufficient Coolant Temp For Closed-loop Fuel Control .
P0128-engine Coolant Temp Sensor Engine Is Cold Too Long .
P0128-thermostat Rationality .
P0129-barometric Pressure Out-of-range Low .
P0131-o2 Sensor 1/1 Circuit Low
P0132-o2 Sensor 1/1 Circuit High .
P0133-o2 Sensor 1/1 Slow Response .
P0135-o2 Sensor 1/1 Heater Performance .
P0137-o2 Sensor 1/2 Circuit Low .
P0138-o2 Sensor 1/2 Circuit High .
P0139-o2 Sensor 1/2 Slow Response .
P0141-o2 Sensor 1/2 Heater Performance .
P0151-o2 Sensor 2/1 Circuit Low .
P0152-o2 Sensor 2/1 Circuit High .
P0153-o2 Sensor 2/1 Slow Response .
P0155-o2 Sensor 2/1 Heater Performance .
P0157-o2 Sensor 2/2 Circuit Low .
P0158-o2 Sensor 2/2 Circuit High
P0159-o2 Sensor 2/2 Slow Response .
P0161-o2 Sensor 2/2 Heater Performance
P0171-fuel System 1/1 Lean
P0172-fuel System 1/1 Rich
P0174-fuel System 2/1 Lean .
P0175-fuel System 2/1 Rich
P0180-fuel Temperature Sensor Signal Voltage Too High
P0180-fuel Temperature Sensor Signal Voltage Too Low
P0190-fuel Press Sensor Signal Voltage Too High
P0190-fuel Press Sensor Signal Voltage Too Low.
P0191-fuel Press Sensor Afterrun Negative Plausibility.
P0191-fuel Press Sensor Afterrun Positive Plausibility.
P0201-cylinder 1-injector Circuit Current Decrease.
P0201-cylinder 1-injector Circuit Load Drop .
P0201-cylinder 1-injector Circuit Overcurrent High Side.
P0201-cylinder 1-injector Overcurrent Low Side.
P0201-fuel Injector 1 Circuit
P0202-cylinder 2-injector Circuit Current Decrease.
P0202-cylinder 2-injector Circuit Load Drop
P0202-cylinder 2-injector Circuit Overcurrent High Side. .
P0202-cylinder 2-injector Circuit Overcurrent Low Side.
P0202-fuel Injector 2 Circuit .
P0203-cylinder 3-injector Circuit Overcurrent High Side.
P0203-cylinder 3-injector Circuit Overcurrent Low Side. .
P0203-fuel Injector 3 Circuit
P0204-cylinder 4-injector Circuit Current Decrease.
P0204-cylinder 4-injector Circuit Load Drop
P0204-cylinder 4-injector Circuit Overcurrent High Side. .
P0204-cylinder 4-injector Circuit Overcurrent Low Side
P0204-fuel Injector 4 Circuit
P0205-fuel Injector 5 Circuit
P0206-fuel Injector 6 Circuit
P0234-boost Pressure Sensor Negative Deviation.
P0235-boost Pressure Sensor Plausibility.
P0235-boost Pressure Sensor Signal Voltage Too High .
P0235-boost Pressure Sensor Signal Voltage Too Low
P0251-fuel Quantity Solenoid Open Or Short Circuit .
P0252-fuel Quantity Solenoid Circuit Malfunction
P0253-fuel Quantity Solenoid Short To Ground .
P0254-fuel Quantity Solenoid Short Circuit. . .
P0299-boost Pressure Sensor Positive Deviation
P0300-misfire Detected
P0300-multiple Cylinder Misfire .
P0301-cylinder 1 Misfire . . .
P0301-misfire Detected Cylinder #1
P0302-cylinder 2 Misfire .
P0302-misfire Detected Cylinder #2
P0303-cylinder 3 Misfire .
P0303-misfire Detected Cylinder #3 .
P0304-cylinder 4 Misfire . .
P0304-misfire Detected Cylinder #4
P0305-cylinder 5 Misfire .
P0306-cylinder 6 Misfire . . . . . .
P0315-no Crank Sensor Learned .
gmctd
Texas
P0325-knock Sensor 1 Circuit .
P0330-knock Sensor 2 Circuit .
P0335-crankshaft Position Sensor Circuit Incorrect Or Missing Signal
P0335-crankshaft Position Sensor Circuit.
P0339-crankshaft Position Sensor Circuit Intermittent Incorrect Or Missing Signal.
P0339-crankshaft Position Sensor Intermittent
P0340-camshaft Position Sensor Circuit Missing Signal Plausibility.
P0340-camshaft Position Sensor Circuit Missing Signal.
P0340-camshaft Position Sensor Circuit.
P0344-camshaft Position Sensor Intermittent Or Missing Signal.
P0344-camshaft Position Sensor Intermittent Signal Plausibility
P0344-camshaft Position Sensor Intermittent .
P0401-egr Solenoid Circuit Negative Deviation.
P0402-egr Solenoid Circuit Positive Deviation.
P0403-egr Solenoid Circuit Excessive Current
P0403-egr Solenoid Circuit Open Circuit.
P0420-catalyst 1/1 Efficiency .
P0430-catalyst 2/1 Efficiency
P0440-general Evap System Failure .
P0441-evap Purge System Performance .
P0443-evap Purge Solenoid Circuit
P0452-nvld Pressure Switch Stuck Closed.
P0453-nvld Pressure Switch Stuck Open.
P0455-evap Purge System Large Leak .
P0456-evap Purge System Small Leak .
P0457-loose Fuel Cap .
P0460-fuel Level Sensor Circuit Signal Voltage Too High .
P0460-fuel Level Sensor Circuit Signal Voltage Too Low .
P0461-fuel Level Sensor 1 Performance
P0462-fuel Level Sensor 1 Circuit Low .
P0463-fuel Level Sensor 1 Circuit High .
P0480-cooling Fan 1 Control Circuit.
P0480-fan 1 Control Circuit Excessive Current.
P0480-fan 1 Control Circuit Open Circuit.
P0480-fan 1 Control Circuit Short Circuit.
P0480-fan 1 Control Circuit Short To Ground .
P0481-fan 2 Control Circuit Excessive Current.
P0481-fan 2 Control Circuit Open Circuit.
P0481-fan 2 Control Circuit Short Circuit.
P0481-fan 2 Control Circuit Short To Ground .
P0481-fan 2control Circuit Excessive Current.
P0489-egr Solenoid Circuit Short Circuit.
P0490-egr Solenoid Circuit Short Circuit.
P0498-nvld Canister Vent Valve Solenoid Circuit Low .
P0499-nvld Canister Vent Valve Solenoid Circuit High .
P0501-vehicle Speed Sensor 1 Performance .
P0501-vehicle Speed Sensor Plausibility .
P0503-vehicle Speed Sensor 1 Erratic.
P0504-brake Switch Signal Circuits Plausibility With Redundant Contact .
P0506-idle Speed Performance Lower Than Excepted .
P0507-idle Speed Performance Higher Than Excepted .
P0508-idle Air Control Valve Sense Circuit Low.
P0509-idle Air Control Valve Sense Circuit High
P0513-invalid Skim Key .
P0513-skim System Invalid Key Code Received
P0513-skim System Read Access To Eeprom Failure.
P0513-skim System Write Access Toeeprom Failure.
P0513-skim System Write Access To Eeprom Failure.
P0520- Oil Press Sensor Circuit Malf Plausibility.
P0520-oil Press Sensor Ckt Malf Signal Voltage Too High.
P0520-oil Press Sensor Ckt Malf Signal Voltage Too Low.
P0522-oil Pressure Too Low .
P0530- A/c Press Sensor Circuit Malf Plausibility.
P0530- A/c Press Sensor Circuit Voltage Too High
P0530- A/c Press Sensor Circuit Voltage Too Low .
P0532-a/c Pressure Sensor Circuit Low (esp).
P0533-a/c Pressure Sensor Circuit High (esp).
P0560-ecm Voltage Too High .
P0560-ecm Voltage Too Low .
P0562-battery Voltage Low .
P0563-battery Voltage High .
P0564-s/c Switch #1 Signal Circuit Plausibility .
P0564-s/c Switch #1 Signal Circuit Stuck Switch.
P0564-s/c Switch #1 Signal Circui Voltage Too High.
P0564-s/c Switch #1 Signal Circuit Voltage Too Low .
P0571-brake Switch 1 Performance .
P0572-brake Switch 1 Stuck On .
P0573-brake Switch 1 Stuck Off .
P0580-speed Control Switch 1 Circuit Low.
P0581-speed Control Switch 1 Circuit High.
P0582-speed Control Vacuum Control Circuit.
P0585-s/c Switch Plausibility Between Switch #1 And #2.
P0586-speed Control Vent Control Circuit.
P0589-s/c Switch #2 Signal Circuit Plausibility .
P0589-s/c Switch #2 Signal Circuit Stuck Switch.
P0589-s/c Switch #2 Signal Circui Voltage Too High.
P0589-s/c Switch #2 Signal Circuit Voltage Too Low .
P0594-speed Control Servo Power Relay Circuit .
P0600-ecm Communication Error .
P0600-ecm Recovery .
P0600-serial Communication Link .
P0601-internal Memory Checksum Invalid.
P0602-ecm Invalid Code Word
P0606-ecm Checksum Error
P0606-ecm Deviation Error .
P0606-ecm Internal Error .
P0606-internal Ecm Processor .
P0610-automatic Transmissio Coded As Manual Transmission .
P0610-manual Transmission Code As Automatic Transmission .
P0615-starter Relay Circuit Excessive Current .
P0615-starter Relay Circuit Open Circuit .
P0616-starter Relay Circuit Short To Ground.
P0617-starter Relay Circuit Short Circuit .
P0622-generator Field Control Circuit.
P0627-fuel Pump Control Circuit .
P0630-vin Not Programmed In Pcm.
P0632-odometer Not Programmed In Pcm .
P0633-skim Key Not Programmed In Pcm .
P0641-sensor Supply 1 Voltage Too High
P0641-sensor Supply 1 Voltage Too Low.
gmctd
Texas
P0645-a/c Clutch Control Circuit .
P0645-a/c Clutch Relay Circuit Excessive Current .
P0645-a/c Clutch Relay Circuit Open Circuit .
P0645-a/c Clutch Relay Circuit Short To Ground.
P0645-a/c Clutch Relay Short Circuit .
P0651-sensor Supply 2 Voltage Too High.
P0651-sensor Supply 2 Voltage Too Low.
P0670-glow Plug Controller Circuit Malfunction .
P0671-glow Plug 1 Plug Failure .
P0671-glow Plug 1 Plug Short Circuit .
P0672-glow Plug 2 Plug Failure . .
P0672-glow Plug 2 Plug Short Circuit .
P0673-glow Plug 3 Plug Failure .
P0673-glow Plug 3 Short Circuit .
P0674-glow Plug 4 Plug Failure .
P0674-glow Plug 4 Short Circuit .
P0683-glow Plug Module Signal Circuit Malfunction .
P0685-asd Relay Control Circuit Shuts Off Too Early.
P0685-asd Relay Control Circuit Shuts Off Too Late .
P0685-auto Shutdown Control Circuit.
P0686-ecm Voltage Error Low .
P0687-ecm Voltage Error High .
P0688-auto Shutdown Sense Circuit Low .
P0697-sensor Supply 3 Voltage Too High.
P0697-sensor Supply 3 Voltage Too Low.
P0700-tcm Dtc .
P0700-transmission Control System (mil Request).
P0836-transfer Case Position Sensor Plausibility.
P0836-transfer Case Position Sensor Signal Voltage Too High
P0836-transfer Case Position Signal Voltage Too Low.
P0850-park/neutral Switch Performance .
P0864-tcm Torque Reduction Signal Error.
P1001-ignition Key Off Timer Performance - Too Fast.
P1002-ignition Key Off Timer Performance - Too Slow .
P1101-acm Crash Signal Recieved .
P1102-viscous/cabin Heater Relay Excessive Current .
P1102-viscous/cabin Heater Relay Open Circuit .
P1102-viscous/cabin Heater Relay Short Circuit .
P1102-viscous/cabin Heater Relay Short To Ground.
P1115-general Temperature Rationality.
P1131-glow Plug Module Internal Fault .
P1131-glow Plug Module Voltage Supply.
P1135-glow Plug Module Control Circuit Excessive Current.
P1135-glow Plug Module Control Circuit Open Circuit.
P1135-glow Plug Module Control Circuit Shorted To Ground
P1135-glow Plug Module Control Circuit Shorted To Voltage .
P1140-vacuum Reservoir Solenoid Circuit Short To Ground .
P1140-vacuum Reservoir Solenoid Open Circuit .
P1140-vacuum Reservoir Solenoid Short Circuit .
P1142-fuel Pressure Solenoid Open Circuit .
P1142-fuel Pressure Solenoid Plausibility .
P1142-fuel Pressure Solenoid Short Circuit .
P1143-fuel Rail Pressure Malfunction Positive Pressure Deviation .
P1144-fuel Rail Pressure Malfunction Positive Volume Deviation .
P1145– Fuel Rail Pressure Malfunction Negative Pressure Deviation .
P1148-fuel Rail Pressure Malfunction Pressure Drop In Overrun
P1151-fuel Rail Pressure Malfunction Maximum Positive Deviation .
P1152-fuel Rail Pressure Malfunction Positive Dev Fuel Press Sol Setpoint.
P1153-fuel Rail Pressure Malfunction Negative Dev Fuel Press Sol Setpoint. .
P1154-fuel Rail Pressure Malfunction Rail Pressure Is Too Low.
P1155-fuel Rail Pressure Malfunction Rail Pressure Is Too High.
P1156-fuel Rail Pressure Malfunction Plausibility .
P1159-improper Start Attempt
P1160-ign Voltage .
P1167-capacitor Voltage 1 .
P1169- Ecm A/d Converter Error
P1250-vacuum Reservoir Solenoid Open Circuit .
P1251-vacuum Reservoir Solenoid Short To Ground.
P1252-vacuum Reservoir Solenoid Short Circuit .
P1259 - glow plug module control over current
P1260 - glow plug #1 control circuit open
P1261 - glow plug #1 control circuit low
P1262 - glow plug #2 control circuit open
P1263 - glow plug #2 control circuit low
P1264 - glow plug #3 control circuit open
P1265 - glow plug #3 control circuit low
P1266 - glow plug #4 control circuit open
P1267 - glow plug #4 control circuit low
P1593-speed Control Switch 1 Stuck.
P1602–pcm Not Programmed .
P1603-pcm Internal Dual-port Ram Communication Failure
P1604-pcm Internal Dual-port Ram Read/write Integrity Failure .
P1607-pcm Internal Shutdown Timer Rationality .
P1696-eeprom Memory Write Denied/invalid.
P1697-emr (sri) Mileage Not Stored .
P2074-manifold Pressure/throttle Position Correlation.
P2096-downstream Fuel Trim System 1 Lean.
P2097-downstream Fuel Trim System 1 Rich.
P2098-downstream Fuel Trim System 2 Lean.
P2099-downstream Fuel Trim System 2 Rich.
P2101-egr Air Flow Control Valve Excessive Current .
P2101-egr Air Flow Control Valve Open Ckt.
P2120-acc Pedal Position Sensor 1 Circuit Voltage Too High .
P2120-acc Pedal Position Sensor 1 Circuit Voltage Too Low.
P2120-acc Pedal Position Sensor 1 Ckt Plausibility .
P2125-acc Pedal Position Sensor 2 Ckt Plausibility .
P2125-acc Pedal Position Sensor 2 Signal Voltage Too High.
P2125-acc Pedal Position Sensor 2 Signal Voltage Too Low.
P2141-egr Air Flow Control Valve Short To Ground.
P2142-egr Air Flow Control Valve Short Circuit .
P2147 Injector Bank 1 Open Circuit .
P2148-bank 1-injector Short Circuit .
P2151-bank 2 Short Circuit .
P2151-bank 2- Open Circuit .
P2181-cooling System Performance .
P2226 Barometric Pressure Circuit Signal Voltage Too High.
P2264-water In Fuel Voltage Above Upper Limit .
P2264-water In Fuel Voltage Below Lower Limit .
P2294-fuel Pressure Solenoid Open Circuit .
P2295-fuel Pressure Solenoid Short To Ground.
P2296-fuel Pressure Solenoid Short Circuit .
P2302-ignition Coil 1 Secondary Circuit- Insufficient Ionization .
P2305-ignition Coil 2 Secondary Circuit- Insufficient Ionization .
P2308-ignition Coil 3 Secondary Circuit- Insufficient Ionization .
P2311-ignition Coil 4 Secondary Circuit- Insufficient Ionization .
P2314-ignition Coil 5 Secondary Circuit- Insufficient Ionization .
P2317-ignition Coil 6 Secondary Circuit- Insufficient Ionization
P2503-charging System Output Low .
P2525-vacuum Reservoir Solenoid Open Circuit .
P2527-vacuum Reservoir Solenoid Short To Ground.
P2528-vacuum Reservoir Solenoid Short Circuit .
Powertrain Verification Test .
U0001–can C Bus .
U0101–lost Communication With Tcm .
U0121-lost Communication With Anti-lock Brake Module .
U0140-lost Communication With Body Control Module .
U0155-lost Communication With Cluster.
U0168-lost Communication With Skim/skreem (wcm).
U110c-no Fuel Level Bus Message Received .
U110e-lost Ambient Temperature Message .
U1110-lost Vehicle Speed Message.
U1113-lost A/c Pressure Message .
U1120-lost Wheel Distance Message
U1411-implausible Fuel Volume Signal Received .
U1412-implausible Vehicle Speed Signal Received .
U1417-implausible Left Wheel Distance Signal Received.
U1418-implausible Right Wheel Distance Signal Received.
gmctd
Texas
Transmission Diagnostics
P0122-tps/app Circuit Low .
P0123-tps/app Circuit High .
P0124-tps/app Intermittent
P0218-high Temperature Operation Activated.
P0602-control Module Programming Error/not Programmed .
P0604-internal Control Module Ram.
P0605-internal Control Module Rom .
P0613-internal Tcm .
P0613-internal Transmission Processor .
P0706-transmission Range Sensor Rationality.
P0711-transmission Temperature Sensor Performance.
P0712-transmission Temperature Sensor Low .
P0713-transmission Temperature Sensor High.
P0714-transmission Temperature Sensor Intermittent .
P0715-input Speed Sensor 1 Circuit
P0720-output Speed Sensor Circuit
P0725-engine Speed Sensor Circuit .
P0731-gear Ratio Error In 1st .
P0732-gear Ratio Error In 2nd .
P0733-gear Ratio Error In 3rd . .
P0734-gear Ratio Error In 4th .
P0735-gear Ratio Error In 5th
P0736-gear Ratio Error In Reverse
P0740-tcc Out Of Range .
P0750-lr Solenoid Circuit .
P0755-2/4 Solenoid Circuit .
P0755-2c Solenoid Circuit .
P0760-od Solenoid Circuit
P0765-ud Solenoid Circuit .
P0770-4c Solenoid Circuit
P0841-lr Pressure Switch Rationality .
P0845-2/4 Hydraulic Pressure Test .
P0845-2c Hydraulic Pressure Test .
P0846-2/4 Pressure Switcu Rationality
P0846-2c Pressure Switch Rationality .
P0868-line Pressure Low .
P0869-line Pressure High .
P0870-od Hydraulic Pressure Test
P0871-od Pressure Switch Rationality .
P0875-ud Hydraulic Pressure Test .
P0876-ud Pressure Switch Rationality .
P0882-tcm Power Input Low .
P0883-tcm Power Input High .
P0884-power Up At Speed .
P0888-transmission Relay Always Off .
P0890-switched Battery .
P0891-transmission Relay Always On .
P0897-transmission Fluid Deteriorated.
P0932-line Pressure Sensor Circuit
P0934-line Pressure Sensor Circuit Low.
P0935-line Pressure Sensor Circuit High.
P0944-loss Of Hydraulic Pump Prime .
P0987-4c Hydraulic Pressure Test .
P0988-4c Pressure Switch Rationality .
P0992-2/4/od Hydraulic Pressure Test
P1684-battery Was Disconnected .
P1713-restricted Manual Valve In T2 Range.
P1715-restricted Manual Valve In T3 Range.
P1736-gear Ratio Error In 2nd Prime
P1745-transmission Line Pressure Too High For Too Long .
P1775-solenoid Switch Valve Latched In Tcc Position .
P1776-solenoid Switch Valve Latched In Lr Position.
P1790-fault Immediately After Shift
P1793-trd Link Communication Error.
P1794-speed Sensor Ground Error
P1797-manual Shift Overheat
P2700-inadequate Element Volume Lr.
P2701-inadequate Element Volume 2c.
P2702-inadequate Element Volume Od .
P2703- Inadequate Element Volume Ud .
P2704-inadequate Element Volume 4c
P2706-ms Solenoid Circuit .
U0002–can C Bus Off Performance .
U0100 Lost Communication With Ecm/pcm.
U0121 Lost Communication With Abs .
