HOW TO: Decipher the Vehicle Safety Certification Label
BluPhant
Connecticut
VEHICLE SAFETY CERTIFICATION LABEL
A vehicle safety certification label is attached to every DaimlerChrysler Corporation vehicle. The label certifies that the vehicle conforms to all applicable Federal Motor Vehicle Safety Standards.
The label also lists:
† Month and year of vehicle manufacture.
† Gross Vehicle Weight Rating (GVWR). The gross front and rear axle weight ratings (GAWR’s) are based on a minimum rim size and maximum cold tire inflation pressure.
† Vehicle Identification Number (VIN).
† Type of vehicle.
† Bar code.
† Month, Day and Hour (MDH) of final assembly.
† Paint and Trim codes.
† Country of origin.
The label is located above the door hinge on the driver-side A-pillar.
Code:
POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin
      1 = United States
2 Make
      J = Jeep
3 Vehicle Type
      4 = MPV W/O Side Airbags.
      8 = MPV With Side Airbags.
4 Gross Vehicle Weight Rating
      F = 4001 - 5000 lbs.
      G = 5001 - 6000 lbs.
5 Vehicle Line
      K = Liberty 4X2 (LHD)
      L = Liberty 4X4 (LHD)
      M = Cherokee 4X4 (RHD)
6 Series
      3 = Liberty Renegade
      4 = Liberty Sport/Cherokee Sport
      5 = Liberty Limited/Cherokee Limited
7 Body Style
      8 = Sport Utility - 4 Door
8 Engine
      K = 3.7L 6 cyl MPI Gasoline
      1 = 2.4L 4 cyl MPI Gasoline
      7 = 2.5L 4 cyl Diesel
9 Check Digit 0 through 9 or X
10 Model Year
      2=2002, etc
11 Assembly Plant
      W = Toledo North Assembly Plant
12 thru 17
      Vehicle Build Sequence
BluPhant -- Thanks, this is good information.
Andrea70...........That's interesting.......and welcome to the board and my ancestry is 100% Italian too.......
andrea70
Italy
Thank you for the welcome!
Here i don't write so much, but read, read, read...
I've made some things with and for my KJ, if you've seen my web
pages....also with the help of this site!
