New Splash Guards
grogiefrog
Near Indy
It's lousy weather here today, but warm enough that I took it upon myself to install the splash guards that I bought awhile ago. They weren't that hard to do, but I did have to remove a push pin on each of the rear tire fenders. I hadn't a clue how to remove them other then to pull really hard. I think I saw someone say that you could drill a hole down them, but I would have had to remove the wheel. Not worth it! Other then that, I did lightly scuff up the rear set with the drill while drilling in the screw that holds the bottom on. I'm not happy about that. I might have to order new ones! So much for an amateur. I will get some better pictures when I give her a good wash when better weather returns... next April?!
I had noticed that the fenders already had rock chips, etc. These should help.
[/url]
[/url]
-=JoN=-
67°20'N 14°40'E
lookin good...
you couldve drilled w/o taking off the wheels, cuz, i drilled w/o taking off my wheels......
just be carefull when going around snow berms......like me, it got caught, and it kinda got loose...(front right)
valvestem
Northeast US
Drill W/O Removing Tires
Whatdidyause? A right angle drill? :-k
SiLveRLiB2k2 said:
lookin good...
grogiefrog
Near Indy
Re: Drill W/O Removing Tires
SiLveRLiB2k2 said:
lookin good...
Yes, but you would have to look close to notice the scuffs as a result. Live and learn...
-=JoN=-
67°20'N 14°40'E
SiLveRLiB2k2 said:
lookin good...
nope, just turned the wheel at full lock
