Gear Ratio WHAT????
Diggerfreek
Colorado
Hey there every one. I now have a custom gear ratio/tire size/speed calculator that I have modified for both the NSG 370 and 42RLE. With this, you can enter in a new gear ratio & a tire size and it will tell you how fast you should be going @ XXXX RPM in X gear... PM me you personal email if you would like a copy of the .XLS excel doc...
Gear ratios currently available for the KK
3.21
3.73
4.10
4.56
4.88
adraineva
A gear ratio is the ratio between the number of teeth on both wheels are fitted. This relationship is expressed mathematically. For example,
Gear no - 1 Group Teeth - 9 Loose Gear - 51 Overall Ratio - 17.40
Gear no - 2 Group Teeth - 12 Loose Gear - 42 Overall Ratio - 10.71
Gear no - 3 Group Teeth - 16 Loose Gear - 39 Overall Ratio - 7.47
Gear no - 4 Group Teeth - 19 Loose Gear - 35 Overall Ratio - 5.65
Gear ratios are used to help define the machine’s performance.
ptsb5a
Northern Alberta, Canada
What???
Did you borrow some of Edison's "new math"? In vehicles it's an expression of the relationship between driveshaft and axle rotations. In a 4.88 geared diff, a steeper, or numerically higher gear ratio, the driveshaft rotates 4.88 times for 1 axle rotation. There, simple gearhead math. The steeper (to a point) the better when running fat tires because a taller tire artificially lowers your gear ratio as far as torque applied to pavement is concerned.
eyehatetofu
Buckeye, AZ
What???
Way to teach that spammer something :p
Even though that guy will never be back, I'm sure the information can be of use to someone :D
ptsb5a
Spammer??? Damn, I miss out on all the cool stuff. I should have said that gear ratios in vehicles are calculated with these....
Powermax
somewhere
Diggerfreek has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Got this message when sending mail.
