Go Back   Jeep Liberty Forum - JeepKJ Country > General Forums > Fabrication
Fabrication
Debating An Offroading Lighting Idea
This is a discussion on Debating An Offroading Lighting Idea within the Fabrication forums, part of the General Forums category!
I'm putting this in the "Fabrication" forum because these would take some work. I am a member of SG and ...
Post up DIY mods for the KJ and KK. Vendors please use the "Vendors" forum.
Like Tree59Likes
Old 07-16-2016, 01:57 PM   #1 (permalink)
profdlp's Avatar
Default Debating An Offroading Lighting Idea
I'm putting this in the "Fabrication" forum because these would take some work. I am a member of SG and can get four of these lights for $60:
New U.S. Military Surplus Headlights
These are 24V lights and I would have to replace the sealed beams inside them. I would also have to hunt down the electrical connectors for the back and whip up a wiring harness. Both of these things are quite doable according to the numerous reviews.
What I'm thinking of doing is mounting four of these to my roof rack as offroad lights. I might try to convert them to LED and maybe even make them a 50-50 mix of spot and wide beam.
I'm thinking that on my Army-Green Jeep these might look pretty cool. What do you all think?
LibertyTC and TwoBobsKJ like this.
--Prof
________________________________________
Prof's 2007 Liberty Project
927/948 OME Springs*Bilstein Shocks*JBA Upper Control Arms*General Grabber AT2 255-70-16*Rage Black Widow Roof Rack*Viper 3606V Alarm System
profdlp is offline   Reply With Quote
Old 07-16-2016, 02:21 PM   #2 (permalink)
CactusJacked's Avatar
I like those. They would match mine better though.
profdlp likes this.
02 Renegade, 5-speed manual.
265/75R16 BF Goodrich Rugged Terrain.
OME/Frankenlift, OME shocks. JBA cut CV axles.
Those who think they know everything are especially annoying to those of us who actually do.
CactusJacked is offline   Reply With Quote
Old 07-16-2016, 05:23 PM   #3 (permalink)
profdlp's Avatar
I just bought four of them. Now to hunt down the rest of the parts...
I also remembered that I had a coupon for $10 off any order. I ended up getting all four of these for $50.
The daggone replacement 12V bulbs will cost me more than the lights themselves. I might see what the 28V bulbs look like before I change them out. With four of them on there it may not matter if they're all a little dimmer. (I have no idea how much the voltage drop will affect these, for all I know it won't be much and they might just last twice as long before burning out.) On top of that, these bulbs are Hi/Lo replacement headlights, which means I'm going to get a three-position switch so I can run them either Hi-beam, Low-beam, or both. This ought to be interesting.
  • Matte Olive Drab metal housing
  • Sturdy mounting bolt with base plate
  • 2-pole style connection
  • Each has infrared lens for special night work ops
  • Each: 6" x 6" x 4 1/2"d., 24V, 3 lbs.
  • Made in the USA
  • Condition: brand new, never issued.
--Prof
Old 07-17-2016, 09:39 AM   #4 (permalink)
Dave's Avatar
They look like they are good and heavy-duty.
profdlp likes this.
Need More Stuff..
Become a Supporting Member
Old 07-17-2016, 01:55 PM   #5 (permalink)
Personally would NOT DO LEDs , just my opinion but unless you are spending a lot on the bulbs etc , they won't be that bright
How many inches diameter are they ?
Aircraft landing lights may fit and are an awesome longer range light .
I'm building a set of them currently out of some old parts , old fog light housings from a 6 volt system so all wiring will be new of course
LibertyTC and profdlp like this.
MUDD'S MOTORSPORTS
WE DO IFS LIFT INSTALLS
04 Kilimanjaro Edition
05 Limited/stock for now
Old 07-17-2016, 02:45 PM   #6 (permalink)
Funny you should mention aircraft landing lights. I used to use those as the bright beams in my 5-3/4" quad headlight Corvettes. Man do they light up the sky...eh I mean road. Just don't get caught with them, they're illegal. I still have my pair on the shelf.
Old 07-17-2016, 04:22 PM   #7 (permalink)
profdlp's Avatar
I abandoned the LED idea when I started thinking about how bright these are to begin with. First off, the replacement PAR36 bulbs are usually found to be listed as replacement headlights for tractors. If two of them can get Farmer Jones back home after dark then I'm sure four of them will be quite dramatic. Throw in the fact that they are dual-filament and I could conceivably light up all eight filaments at once and I doubt I'd find LEDs that could compete. Now that I'm back in Ohio I expect to spend some time offroad down at the family farm just a few hours away.
I also found a variety of inexpensive bulbs with a wide range of flood/Spot options: https://www.1000bulbs.com/category/50-watt-halogen-par36-sealed-beam/
Tom, to answer your question, they are 6" diameter lights. I'm almost wondering if they might be too big.
--Prof
Old 07-17-2016, 04:35 PM   #8 (permalink)
I used to run them on everything I had
Heading down along the Ohio River near where I lived one night about 4 AM there is one long straight stretch of road , just as I was about out of the curve at one end the lights lit up the door decal on a Sheriffs car . 4 seconds later the lights came on and I'm still aways up the road yet.
Shut the aircraft's off and pulled over
First line is " what the he** were you running and how do I get a set? "
I did work on the Sheriffs personal car ( 70 Olds 442 ) so most of the deputys knew me .
He said I should give ya a ticket but if you install a set for me we'll forget it
MUDD'S MOTORSPORTS
Old 07-17-2016, 04:37 PM   #9 (permalink)
They should work find, people run the 6 and 7 inch lights on a basket all the time. May find a way to mount them as low as possible but will work great I think. Would love to have a set of them to " play " with
profdlp likes this.
MUDD'S MOTORSPORTS
Old 07-20-2016, 09:23 PM   #10 (permalink)
profdlp's Avatar
I received a big box today. It had four smaller boxes inside of it.
(The spark plug box is there to show scale. These are very special lights which don't require their own spark plugs.)
Here is what I have:
Now I need to come up with wiring (which I can figure out), some clear replacement lenses (I have no clue where to find these, but the ones that were included are so solid I am crying over the fact that they are tinted), and also some mounting brackets. I'd like to attach them to the lower ring of my roof basket, which is about 1" in diameter. (Maybe a little less, I'll have to measure it.)
I'd like something like this: 2X 19mm to 25mm Roll Cage Mount Bracket Clamps for Spot Light Tube LED Light Bar
Those apparently ship from the moon, because the ETA for delivery is the middle of August. There are a lot of the name brand companies selling similar items but they have two main drawbacks:
1) They are generally sized for roll bars or bull bars in the 2-3" diameter range, and...
2) The thieves want $30 apiece for them. I am not spending $120 for four tiny little brackets. I am on drugs, but not that kind.
So my question, dear readers, is this: How would you suggest I mount these?
Suggestions welcome, and if you stop by after I get them mounted we can go out and scare deer together some dark evening.
--Prof
