Go Back   Jeep Liberty Forum - JeepKJ Country > JeepKJ.com -Jeep KJ Country > Just registered? Post here to introduce yourself!
New to Jeep KJ
This is a discussion on New to Jeep KJ within the Just registered? Post here to introduce yourself! forums, part of the JeepKJ.com -Jeep KJ Country category!
Hi all, I just purchased a 2005 Jeep Liberty KJ. I'm new to the whole KJ scene. As I was ...
Like Tree7Likes
Old 12-19-2018, 06:45 PM   #1 (permalink)
Default New to Jeep KJ
Hi all,
As I was looking around for a KJ - I wanted either the 05 -06 year gasser to be able to swap the front springs to the crd diesel front springs , as I was looking for a reliable compact 4x4 SUV for driveway snow plowing (& soccer taxi for the kids), the KJ was at the top of the list. The swapping of the springs allows for the extra weight of the plow. I researched all about the ESP due to most of the Libby's I looked at were 06's (but Hi milage) they all had the ESP button on the steering column. But when I found a sweet condition 05 at a really good price I realize this does NOT have the ESP button. Does this mean the 05 doesn't have abs/traction control (which may benefit me for my intended use)?
Any helpful info, guidance, and suggestion would be appreciated.
Thank you in advance,
-TC
Mytmouse is offline   Reply With Quote
Old 12-19-2018, 07:41 PM   #2 (permalink)
Even the ESP button doesn't disable all functions on my 06 Liberty Renegade. Your intended use might benefit from those functions
Jeremy-WI is offline   Reply With Quote
Old 12-19-2018, 07:46 PM   #3 (permalink)
So the 05 does or does not have those functions?
Old 12-19-2018, 08:08 PM   #4 (permalink)
Another question - what's with the rear door release? Opening it , I was only able to open it when I used the key window hatch button, there wise it always seemed to be locked...
Old 12-19-2018, 08:09 PM   #5 (permalink)
Just curious why 05-06 ? Just wondering
Personally with an 03-04 and 05 I like the earlier years way better
MUDD'S MOTORSPORTS
I DO IFS LIFT INSTALLS
04 Kilimanjaro Edition
05 Limited/stock for now
tommudd is online now   Reply With Quote
Old 12-19-2018, 08:37 PM   #6 (permalink)
I wanted either the 05 -06 year gasser to be able to swap the front springs to the crd diesel front springs.
The crd diesel was only available in 05 and 06. Plus I didn't want any older which had even higher mileage....
The diesel front springs are 410# to handle the weight of my snow plow w/o having to go with a lift which is more money and I'm not looking to go rock crawling or anything , just plow driveways and drive kids around town...
Old 12-19-2018, 08:57 PM   #7 (permalink)
Springs are compatible From 02-07 and I think maybe beyond. My 05 sport has abs, but no traction control. I don't think traction control happened til they got 4 wheel abs 05 has a single sensor on rear diff, (3 wire abs)
Bluebert=05 sport, ome 927/948, Yella Bilsteins, 1/4 inch top plate, 7/16 inch left and 3/8 inch conduits, 2 extra isos in back, 245/75 r16 at's. Comfortably sitting at 22 1/2 all the way around.
duderz7 is offline   Reply With Quote
Old 12-19-2018, 09:02 PM   #8 (permalink)
OK little lesson for you, all springs and shocks are the same from 02-07, well fronts are the same till 2012 actually
Plus if only adding front CRD springs I assume you will be using new ones, then rear will be somewhat lower than the front , plus replace the shocks with preferably OME but second best is bilsteins ( good ones, not the cheap ones.
As far as on road or rock crawling,.....well most want the better ride of after market like OME on the road ( plus off) They are built for both . But either way, stock springs are junk, no matter if CRD or not. Over 55 gassers and 4 CRDs to date lifted/ upgraded in my garage so have just a wee bit of experience
MUDD'S MOTORSPORTS
Old 12-19-2018, 09:34 PM   #9 (permalink)
Thanx Tommudd , That's good to know. Thanx for the lesson! That's why I go on these forums - to get info from experienced ppl.
At least I know I found a good Libby; low mileage, low price, decent shape (that I can tell so far)....
So I'll also look into the OME's. I'm just looking for heavier weight support like from the 410# of the crd's. And of course new along with struts/shocks.
So with this 05 you think I am ok with it's traction (or lack of) control, for snow plowing.?
And what's with this rear door release?
Old 12-19-2018, 10:20 PM   #10 (permalink)
ltd02's Avatar
Supporting Member
If the doors are all unlocked then the rear gate glass and door should open when you pull the handle.
BTW my 05 only has ABS too. None of that other stuff.
02blue reincarnated.
2005 Limited STS(71k) 242/42rle/recall hitch/CrossContact 235-65-17/Bright Silver Metallic and shiny plastic covered wheels
2002 Limited (179k) "GONE"
"...if it is a Miracle, any sort of evidence will answer, but if it is a Fact, proof is necessary…." Mark Twain
"There was a time that the pieces fit, but I watched them fall away." -Tool
"To live without Hope is to Cease to live." -Dostoevsky
ltd02 is offline   Reply With Quote
