Traction control light and brake lights
liberty74
Ashtabula Ohio
Pretty much at my wits end with this thing. 2012 liberty having an issue with the traction control light is on. Also noticed the brake lights are on. The brake lights are on while the jeep is running. First time this has happened. Just replaced my left rear wheel speed sensor because the service 4wd, traction control, and abs lights were on. Need to get this figured out tired of all the little problems with this thing. Any thoughts? Thanks.
Jeff
turblediesel
memberable
Alaska
I don't have it on mine but someone here will know. I'd be baffled too.
What's an "absolutely light"?
turblediesel
memberable
Alaska
True!
ABS light will come on if it fails its' start-up check which takes a little time. Check the work that's been done and start looking for a second problem. Got a codereader?
turblediesel
memberable
Alaska
All those systems work together. Mysterious stuff to me; Mine's an '05 KJ.
liberty74
Ashtabula Ohio
No don't have a code reader. Do have access to one though. Have to check things in the morning.
Jeff
