Low beams not working
Clint3240
Mass
I have 2008 Jeep Liberty and the low beams are not working, I can’t locate a fuse or a relay for it in the panel, high beams and every other light works fine. Any suggestions are aprecicated. I have a Haynes manual and that is no use
Billwill
White River, South Africa
The KJs have separate fuses for high and low beam located near the bottom of the interior fuse panel. Also the KJs have a High Beam Relay on the front of the fuse panel and a Low Beam Relay on the reverse side among other identical relays...I have no information regarding the KKs!
The Multifunction Switch on the KJs fail a fair amount...do not know if they fixed it in the KKs.
Have you checked/replaced the bulbs?
Clint3240
Mass
I’m not sure what your talking about kk and kJ? But no I did not check the bulbs, I find it very rare to have both of them blown
reiterating what Bill mentioned.
1. use your owner's manual to find where the appropriate fuse(s) are.
2. check the bulbs whether the low beam filament is blown.
