2009 Jeep Liberty - Electrical Issues - Door Lock and Washer motor
kalpers
MI
My 2009 Jeep Liberty's power locks stopped working so I checked the 25A fuse. The fuse was blown so I replaced it but now the Jeep will only unlock. When I click the lock button nothing happens.
I also have a similar problem with my windshield washer motor. I didn't see any blown fuses. The back washer works but the front doesn't. I saw that both run off the same motor and found that I can just check the voltage at the connector. I am getting voltage to the pump when the back washer motor is coming on but not when the front one turns on.
Not sure if there is something that both have in common or if this is just a coincidence.
