Compatible?
SWilliams
Near Cooperstown NY
Go visit Car-Part.com--Used Auto Parts Market Punch in the info on your vehicle and select sort by year. However I think you will find that on the 05 the doors and glass will fit directly as will most interior parts. The front is different but you can use it, if you swap everything over. Fenders, grill support, grill, bumpers and such, that is because of the relocated turn signals and fog lights. Direct fit parts are 2002-2003. Then once you hit late 2004 the engines are also different because they swapped the entire control systems.
