Go Back   Jeep Liberty Forum - JeepKJ Country > Jeep Liberty - KJ (02 to 07) > Lift Kit Discussion
Lift Kit Discussion
ARB Bumper and OME Lift Help/Advice
This is a discussion on ARB Bumper and OME Lift Help/Advice within the Lift Kit Discussion forums, part of the Jeep Liberty - KJ (02 to 07) category!
Discuss all the different types of lifts and which is right for you.
Like Tree1Likes
Old 02-25-2018, 08:03 PM   #1 (permalink)
Default ARB Bumper and OME Lift Help/Advice
Hi Everyone, I am new here and I am looking for some advice regarding the ARB bumper and the OME lift kit. I have a 2005 3.7L Liberty Sport with 86,000 miles on it. Right now, everything on it is stock and a am rolling on 225/75/16 tires.
So about a year and a half ago the front end of my liberty of clipped by a garbage truck that was turning into an alley while I was parked on the street. There wasnít any serious damage to the car, only the plastic bumper and bumper components were damaged. I filed a claim with the city to cover the damage and have been playing the waiting game. The city finally sent me a check but I do not want to put the plastic stock bumper back on when I can install an ARB bumper on someone elseís dime. I just need some input before I buy the bumper.
I have downloaded the installation instructions for the bumper already and have gone through them several times. I know the mounting system slides on and bolts to the front crossmember. My problem is my sister rear ended someone years ago and I believe she dented my front crossmember a little bit. I donít think it is that bad. I just notice to identical bumps on each side of the bottom of the crossmember. The crush cans on the front of the crossmember are only slightly dented. I didnít really examine/pay attention the crossmember after the car was hit by the garbage truck and I donít really want to take the bumper off because I am afraid it will be difficult to get it back on (I have it jerry rigged on there). So right now I can only see the bottom of the c member. My concern is that if I buy the ARB bumper I will not be able to mount it due to a dent in the crossmember. I really donít want to have the crossmember replaced because I think it needs to be cut out and the new welded in. The apertures in the c member that accept the captive nut channels for the bumper seem undamaged and so do the areas immediately around them. I am thinking that I could just heat and hammer any dents out so I could mount the bumper and it will be ok.
-Does anyone have any experience with installing an ARB bumper on a slightly dented c member?
-Do you think I would be good as long as I could hammer out the dents and the c member is flat on all sides?
-Also, the bumper says it comes in painted grey. Could anyone tell me how close the ARB bumper grey is to the grey that the plastic liberty fender flares are? I wasnít planning on getting it painted.
-Any other advice regarding the bumper and installation?
-I also am planning on putting the OME 1.5Ē lift kit from Jeepinbyal . From what I understand that is really 2.5Ē of lift, is this correct?
-I know I need the OME 927 HD springs in the front if I plan on putting the ARB bumper on but will they be too stiff if I canít install the bumper?
-I also what to make sure I get the correct rear shocks. I was planning on getting the N132L long shocks because from what I understand those are required for a lift. Are they the right ones?
-I donít want to have any negative effects from the lift, specifically in the cv axel and u joint departments. From what I understand as long as I donít go above 23Ē from the center of the wheel to the bottom of the fender flare I should be good. Right now the front measures 18Ē to the bottom of the flare from the center of the wheel on both sides of the car and the rear is at 18.5Ē on both sides of the car. So after the OME 1.5Ē lift I should be at 21.5Ē in the front and 22Ē in the rear, correct? At that height I shouldnít have any cv or u joint issues, correct?
- I am not getting new tires right away. I am planning on rolling on my 225/75/16ís for a while. In the future will I be able to install 245/75ís with the amount of lift I am putting on? I would rather not regear my diffs , so thatís a factor as well. If not what can I put on?
-I am also planning on installing the JBA Upper Control arms. Does anyone know if those come with the ball joint already assembled or do I have to do that myself? And do I need to get ball joint boots and washers or do they come with?
-Finally when installing the lift can I reuse all my other components? Such as rear upper and lower spring isolators, etc.
This is my shopping list, will I need anything else?
*OME 1.5Ē lift kit with 927 HD front springs and N132L long rear shocks, JBA UCAís, terraflex bumpstops, 4 hockey pucks, and an ARB bumper.
Thank you in advance. I know this was a long post and I am asking a lot of questions and many have been addressed in the Lift Faq thread. This is just my first time installing a lift and I want to do it right the first time. I appreciate any advice and input. Thank you
Jeepguy26.2 is offline   Reply With Quote
Old 02-25-2018, 08:18 PM   #2 (permalink)
HoosierJeeper's Avatar
It's more black than gray I think.
Yep, more if you add a topplate/ clevis and rear isolators
My opinion, I liked the 926 more if you don't have a bumper or winch, I thought it flexed better. But tons of people run the 927s with the stock bumper and love it. If you plan on doing a winch with the ARB,
go 790 up front.
Yes!
Correct. At least not anymore than what a normal KJ would
245/75/16 will be fine. Might have to trim the air dam/fender liner.
They come with everything.
Yes. Only think I might recommend replacing are the front upper shock mounts. The bushing comes loose and makes an awful noise. I think I'm the only person that has had it happen, but it's worth it IMO. Get Mopar only.
List looks good! I responded in red. Sorry that I don't know much about the collision damage. I've never installed an ARB so I'm not exactly sure how it mounts. If it's anything like the backbone winch mount I have, I'm guessing if the crossmember isn't fully folded in, it should be ok.
15 KL Limited V6 4x4
07 LR3 SE V8
96 XJ Country
Old 02-25-2018, 09:16 PM   #3 (permalink)
I ran an ARB with 927s on the 04 for 100,000 miles before I upgraded
so have a little experience.
If you are ever going to add a winch go for the 790s ( also ran the ARB and no winch with the 790s.)
But you are on the right track .
As far as regearing some think you don't have to with a 30.5 inch tall tire, ( 245-75-16s or 265-70-16s ) But I'm a firm believer in doing it.
Trust me you can tell the difference , But if you are a flatlander you can get by
MUDD'S MOTORSPORTS
I DO IFS LIFT INSTALLS
04 Kilimanjaro Edition
05 Limited/stock for now
Old 02-26-2018, 12:27 AM   #4 (permalink)
Rich75043's Avatar
All your questions were answered pretty thoroughly but I thought I might chime in about the 927 springs with stock bumper. I just did my lift a few weeks ago and I too was concerned it might be too stiff but I took the advise of the more experienced and just went for it lol. glad I did. it's almost two separate ride qualities now. on the one hand it feels very crisp and responsive on small bumps and road irregularities. on the other, it takes larger bumps and big dips like it just floats across them. very nice ride now...even my wife complimented my jeep and that's unheard of...
2003 Liberty 4x4 Freedom Edition
Rich75043 is offline   Reply With Quote
Old 02-26-2018, 04:06 AM   #5 (permalink)
nbas's Avatar
I agree with everything that has been said.
Regarding the front springs, i have installed both. I installed the 926 first. I used them for 5.000km and they flexed very well. The lift was not what i expected and i had problems with my tires (245/75R16). Tom suggested to replace them with the 927 as they would give more lift. Therefore, i replaced the 926's with the 927's and indeed i got some more lift. So far i have used them for 1.000km and to me they seem Ok although i preffered the flex of the 926's. But this is my personal opinion and i suppose the new one's haven't settled yet.
2004 JEEP KJ Limited
OME lift
FRONT: 2927/90009, Teraflex Bump Stops, Strut Spacer Plate set 1/4" + 1/4" JBA Clevis Spacer (Clevis spacer only left side)
REAR: 2948/n132l, Bump Stops
JBA A-arm
245/75R16 Cooper STT Pro
PML Transmission Pan
Aluminum Alloy Radiator with in radiator transmission cooler
nbas is offline   Reply With Quote
Old 02-26-2018, 10:08 AM   #6 (permalink)
JeepJeepster's Avatar
This is key. My KJ with 245/70/16 tires cant hold 70mph on the slightest of inclines. The throttle must be kept just on the edge of unlocking the torque converter just to stay at 70mph.
It really makes driving the KJ a struggle for me...
The KJ drives great with the stock 215 tires and 3:73 gears....
tommudd likes this.
-2004 Jeep Liberty Limited
-Atlantic Blue
-Transfer Case: NP242
-OME/Rustys Lift
-Powertrax No-slip
-Flowmaster 50 Series SUV
Jeepsters Gallery
Old 02-26-2018, 08:12 PM   #7 (permalink)
Some more to add;
I ran the 04 over 100,000 miles with 4.10s and 32s, always wished it had 4.56s
When I lifted the 03 I knew I wanted 265-70-16s and of course with a spare front and rear diff with 4.10s I threw them in soon after.
Now there is about 100 miles of Interstate lots of rolling hills that I have ran for over 40 years with everything from Harleys to Peterbilts. Then 25 miles of 2 lane roads , and then 4-5 of one lane dirt/ gravel.
Now with 265-70-16s and 3.73s it down shifted over 30 times holding steady 75 on the Interstate, with 4.10s installed one time is all. Now thats less wear and tear on the motor and transmission, more mileage etc
Tells me a lot
MUDD'S MOTORSPORTS
Old 02-27-2018, 03:41 AM   #8 (permalink)
nbas's Avatar
Mine is also downshifting a lot with 245/75R16 and 3.73 gearing. So re-gearing to 4.10 is one of the mods I would like to do next.
OME lift
JBA A-arm
Old 02-27-2018, 12:09 PM   #9 (permalink)
Thanks everyone for the advice. You have been very helpful. Based on what you guys are saying I probably won't upgrade my tires until I could afford to regear to 4.10s.
In regards to that front c member I was asking about, I took off the front end yesterday to get a good look at it and take some pictures. I'll attach some of them. The damage isn't that bad. Has a small dent in the center and the underside is a bit crunched on each side like I was talking about. The apertures are fine.
My plan is to heat and beat that underside flat and slide hammer the front dent a little so I can get the ARB bumper mounting bracket on. Can anyone with experience installing the ARB bumper tell me, based on those pictures, if you think after I reshape the bottom of the crossmember I be able to install the bumper ok and not have any issues?
Thanks again.
Old 02-27-2018, 12:11 PM   #10 (permalink)
How stiff were the 790,s without the winch , just the ARB bumper?
