Register to remove these ads.
How To
Installing jba bolt on tri-angulated 4 link
This is a discussion on Installing jba bolt on tri-angulated 4 link within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Register to remove these ads. It's free! Been a few that have requested a how to on installing the JBA ...
Like Tree6Likes
Old 05-03-2017, 06:02 PM   #1 (permalink)
Default Installing jba bolt on tri-angulated 4 link
Been a few that have requested a how to on installing the JBA Bolt on Tri-Link.
So here goes , or I'll try and explain, I'm one of those who doesn't read nor do How to's
Tools,
15 and 21 MM sockets and ratchet
Jack and jackstands (although I normally don't use them since you can just roll underneath to install )
* If lifting then install jackstands under the axle housing ( installing them under frame diff would hang down and would make it harder to install, IMO )
* So now remove the KJ " balls " ( vibration dampener on the rear diff ) using 15 mm socket
* After removing them loosing the front tri-link bolts which are 15 mm as well.
* 3 bolts that hold the bracket on the diff are 21 mm , these can be a real *itch to remove at times so be ready.
* Now loosen the LCA bolts they are 21mm
* Now you are ready to install the JBA Bolt on 4 link
* Fairly straight forward mount the rear bracket,
* Cut and install the two arms ( they come longer and you'll need cut them down some depending on what height you are .
* I ran mine on 4.5 inch lift about 18-18.5 inch eye to eye to get the angles I wanted your's will be different depending on lift. Forget now on the measurements on the 03 right now.
* Use loc-tite on the bolts into the rear diff.
Bolt everything back up and if have the rear diff hanging down drop on ground and tighten the rear LCA's .
I think thats about it, If I remember anything I'll add.
Will take pics next time I'm under mine
Now take out and enjoy, you'll notice a difference from the get-go !
Oh to to cut them just grab your Metabo Angle Grinder and then round the edges on your bench mounted grinder
TwoBobsKJ and Kj/toy like this.
MUDD'S MOTORSPORTS
WE DO IFS LIFT INSTALLS
04 Kilimanjaro Edition
05 Limited/stock for now
tommudd is online now   Reply With Quote
Old 05-03-2017, 06:21 PM   #2 (permalink)
And since my Photobucket account that has Jeep pics on went on vacation, will find or take some later
MUDD'S MOTORSPORTS
Old 05-03-2017, 06:26 PM   #3 (permalink)
Thanks! Tried to thank you in the PM, but it says you're out of storage space
Also - what I got from Marlin (and I'm gathering that these may just be starting points given what you have listed):
2.5" lift - 18.5" eye to eye
4" lift - 19.25" eye to eye
Now you have me rethinking the process I was going to work - I'm going to be adding in those isolators when I do this, so was going to jackstand the body rails to get that pumpkin dropped and with the UCA out, should be a breeze getting the isolators in. Now I'm thinking I may need to drop it to put the arms on after the bracket is on.
07 KJ Sport
JBA Coilovers, UCA's and Shocks
2.5" Lift
3.7L Gasser
1.5" Spydertrax spacers
Kenwood KDC-X700 Stereo
rockdart is offline   Reply With Quote
Old 05-03-2017, 07:18 PM   #4 (permalink)
Why would you need to drop it, or am I misunderstanding what you think you need to do ?
The above measurements are sort of a starting point
MUDD'S MOTORSPORTS
Old 05-03-2017, 07:22 PM   #5 (permalink)
I'm out of space every other week
MUDD'S MOTORSPORTS
Old 05-03-2017, 07:35 PM   #6 (permalink)
Just get it back on the ground to put the arms on might help given what you wrote. Probably be less fighting to get to the correct length for the pinion too. After the isolators go in, my height going into it will be different.
07 KJ Sport
2.5" Lift
3.7L Gasser
Old 05-03-2017, 09:01 PM   #7 (permalink)
wheeee32's Avatar
What are the KJ "balls"?
Originally Posted by m_volyrakis:
"I recently removed my girlfriend.
Although this mode didn't affect my ground clearance, it drastically improved my off-road capabilities!"
2006 Jeep Liberty: Jeepin' By Al's Adjust-A-Struts on the front, Al's Upper A-arms, 1 extra upper iso in the rear on each side, OME948 H/D Rear Springs with OME132L Rear Long Travel Shocks, 4:10's, Duratrac 245-75-16's.
wheeee32 is offline   Reply With Quote
Old 05-03-2017, 09:15 PM   #8 (permalink)
Vibration dampener that is mounted to the rear diff and hang down
Sorry we all used to call them that back what now seems years ago.
There updated for the newbies !
MUDD'S MOTORSPORTS
Old 05-03-2017, 09:30 PM   #9 (permalink)
wheeee32's Avatar
Haha! Oh yeah! It's been a while since I've been underneath my KJ in the back. I remember thinking that when I saw them. Thank you for posting up the information Tom. I'll be holding on to it for when I finally put the tri-angulated 4 link on my KJ.
Old 06-17-2017, 11:20 PM   #10 (permalink)
mightybeet's Avatar
Send a message via AIM to mightybeet
so ya can do do this will all 4 tires on the ground?... my rear is clunking and prolly need whole new rear everything.
2004 jeep liberty columbia edition 3.7 300k+ miles
2012 jeep patriot latitude not so many miles
parking lots are off road
mightybeet is offline   Reply With Quote
