Register to remove these ads.
How To
HOW TO: Tweak your Keyless Entry settings
This is a discussion on HOW TO: Tweak your Keyless Entry settings within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Register to remove these ads. It's free! Here's some tips on how you can tweak your Jeep's keyless entry system ...
Like Tree1Likes
Old 12-14-2004, 12:47 PM   #1 (permalink)
BluPhant's Avatar
Send a message via ICQ to BluPhant Send a message via AIM to BluPhant
Default HOW TO: Tweak your Keyless Entry settings
Here's some tips on how you can tweak your Jeep's keyless entry system to fit your indiviaul needs. Many of these options are available to program with an EVIC, but if your Libby is not equipped with one, you can still make some changes to suit your needs. The features below are available to anyone who has a keyless entry system, regardless of whether it is equipped with Sentry key/Alarm.
AUTOMATIC (ROLLING) LOCKS
This is the "Lock when the vehicle is going 15mph" feature. This feature can also be disabled through the EVIC.
The rolling locks feature can be toggled ON/OFF by using the DRB IIIt only.
HORN CHIRP DISABLING / ENABLING
This controls if you want your Libby to beep the horn when locking via the keyless entry. * Reports indicate that this does not work for 05 mdoels.
To DISABLE (cancel) the horn chirp feature,
Press and hold the transmitter LOCK button for four to ten seconds.
While pressing the LOCK button in, press the UNLOCK button.
Release both buttons.
To ENABLE the horn chirp feature, repeat the above procedure.
OPTICAL CHIRP (FLASH) DISABLING / ENABLING
This controls if you want your Libby to flash the hazard lights when locking/unlocking via the keyless entry.
To DISABLE (cancel) the optical chirp feature,
While pressing the LOCK button in, press the TAILGATE RELEASE button.
To ENABLE the optical chirp feature, repeat the above procedure.
TAIL GATE RELEASE DELAY
The liberty can be set to pop the tailgate instantly when you press the button, or require it to be pressed and held for it to open
Press the UNLOCK button for four to ten seconds.
While pressing the UNLOCK button, press the TAIL GATE RELEASE button.
This will toggle between PRESS AND HOLD and PRESS (no delay).
UNLOCK SEQUENCE
When unlocking the liberty, you can choose between unlocking drivers door first or unlocking all doors simultaneously.
Press and hold the transmitter UNLOCK button for four to ten seconds.
While pressing the UNLOCK button in, press the LOCK button.
This will toggle between Driver door first and Unlock all doors function.
GranpaQB likes this.
2oo2 Liberty Sport [Patriot Blue]
Leather Seats/Alpine iDA-X001 HU/SC-C1 Sirius Tuner/Wheel Locks/Foglites/nüvi 200W GPS
EVIC from 2ooo GC/EVS II Security (Sentry Key)/Under-Dash Courtesy Lights/Hunter 4x4 steps
Rear Flipper Glass Pad/Trail Rated Badge/Custom tin
t
2oo7 Commander Limited [Black]
V8 4.7l Flex Fuel, Remote Start, GPS, Saddle Brown Leather, REC GPS, VES, Sirius, Tow Package
"No one can make you feel inferior without your consent."
Eleanor Roosevelt, 'This Is My Story,' 1937
BluPhant is offline   Reply With Quote
Old 12-14-2004, 05:57 PM   #2 (permalink)
yoda13's Avatar
Blu-
This is a great how-to, I wasn't aware of the ability to tweak the system. I am going to have to modify it a bit. Thanks.
Yoda
For over a thousand generations, the Jedi Knights were the guardians of peace and justice in the Old Republic. Before the dark times, before the Empire.
LIVESTRONG
-Put this in your profile if you know someone who is fighting, has survived, or died of cancer
JeepKJ Country #025
2007 White Jeep Wrangler X 2-door
yoda13 is offline   Reply With Quote
Old 12-14-2004, 06:50 PM   #3 (permalink)
BluPhant's Avatar
Ya.. I knew you could do it with the EVIC, but didnt realize you could do w/o. Stumbled across this in the service manual when I was looking for something else.
LMK how it turns out.
-Blu
t
Old 02-28-2005, 09:45 PM   #4 (permalink)
Send a message via AIM to Aerostar6
yo blue, can i steal this for my site? http://www.spanosg.com/Jeep/
Aerostar6 is offline   Reply With Quote
Old 02-28-2005, 10:21 PM   #5 (permalink)
TRAILN's Avatar
Awesome =D>
Did someone say grocery getter?
TRAILN is offline   Reply With Quote
Old 03-01-2005, 02:07 PM   #6 (permalink)
BluPhant's Avatar
Sure... get the info out there
-Blu
t
Old 03-03-2005, 08:39 PM   #7 (permalink)
TRAILN's Avatar
Default Re: HOW TO: Tweak your Keyless Entry settings
I really could use a delay, I've accidentally poped it many times. It won't work for me. Tried it a few times but still no delay
Old 03-04-2005, 11:11 AM   #8 (permalink)
Trodo's Avatar
I really liked the unlock sequence. That was totally cool! I can't believe that worked. Great find!
Trodo is offline   Reply With Quote
Old 06-01-2005, 11:31 AM   #9 (permalink)
Send a message via AIM to styng88
I don't get it. I want to disable this, but what is DRB IIt??
Liberty Sport- Built February 02
3.7
Auto
JVC indash MP3
styng88 is offline   Reply With Quote
Old 06-01-2005, 02:17 PM   #10 (permalink)
Corwyyn's Avatar
It's the scan tool the dealer uses for diagnostics; it can also be used to reprogram things like the rolling lock, change tire size in memory so your speedo is correct if you get bigger tires, etc.
Kevin
'03 Flame Red Liberty
"A stick of dynamite to blow out the side of the tomb, scoop the bones aside, you grab the Amulet and you run"
I. Jones
American Journal of Archaeology
1932
Corwyyn is offline   Reply With Quote
