Register to remove these ads.
How To
HOW TO: Improve your MPG
This is a discussion on HOW TO: Improve your MPG within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Like Tree5Likes
Old 08-05-2006, 08:05 PM   #1 (permalink)
Default HOW TO: Improve your MPG
Register to remove these ads. It's free!
I liked my reply to a post so much I decided to turn it into a How To.
This post is brought to you by Scotch Ale, made by your friends and mine at Depot Street Brewing. So dark, not even light can escape (not their official motto, but that's how I've been pitching it).
DISCLAIMER: I have a tendency to be brutally honest (especially when I've been drinking). Some people may take it the wrong way, but remember, it's nothing personal, I'm just an ass (especially when I've been drinking).
Most manufacturers have already done everything they can to improve your MPG. These days, it's a great selling point. Translation: you will sell more vehicles if they have better fuel economy. They only limiting factor are those bastards at the EPA and their emission standards.
There are 6 things you can do to improve you fuel economy:
#1 Change your driving habits. Slowly accelerate from stops, don't accelerate uphill, coast downhill as much as possible, draft, and don’t go above 60 mph.
#2 Increase your airflow by adding an aftermarket intake and exhaust (with mandrel bends). (There isn't much cost benefit here, MPG increase is minimal and parts aren't cheap). This will give you a slightly leaner air/fuel ratio (ideal is 17:1). This ensures there is enough oxygen present to achieve as close to 100% combustion as possible. There will be an increase in H20, CO2 emissions along with NOx (NO, NO2 and N2O), and a decrease in non-combusted hydrocarbon emissions. Any change will be minimal and SHOULDN"T (but might) affect emission tests. An increase in air also increases the number of particles you let into the engine, decreasing engine life. Again the effects are minimal.
#3 Add an underdrive pulley. Basically, this robs power from other components on the drive belt and delivers it to the engine. Those components include: your A/C (so it won't cool as well), power steering, and your alternator (so your battery won't recharge as quickly). Not very cost effective and you gains will be minimal. The pros might not outweigh the cons if you like your A/C or you pull a lot of current.
#4 Improve your aerodynamics. Lower the front end and spray your entire vehicle with Teflon. You chose the wrong vehicle for aerodynamics, and it's not a very cost effective solution.
#5 Lose some weight. Don't carry around unnecessary weight. You lose 1% economy for every 100 pounds. Go on a diet, take a dump, whatever it takes to drop a few pounds (pun intended). For more extreme results Lose the A/C compressor, radio, roof rack, spare tire and jack, all the seats (except the driver's seat), and all of your interior molding and upholstery. You could probably eliminate 250 pounds and gain .5 mpg efficiency. But think of all the money you'd make selling parts of eBay!
6 Move to sea level, or below (stay above the water please). You lose 3%-4% economy for every 1000 feet you are above sea level (unless you have a supercharger or turbocharger to cram more air in).
I'd like to thank my friends Copy & Paste, Microsoft Word, SpellChecker and alcohol, the cause of...and solution to, all of life's problems.
2004 Liberty Rocky Mountain Edition - Black w/ Towing Package
Added: EVIC w/ Homelink & TPMS, OEM Seat Covers, OEM Slush Mats, Weathertech cargo liner and Weatherflectors - slide in air deflectors, Rusty's Strut Plates, OEM Rockrails and full skids, Tow hooks, Lightbar and Renegade Basket, 06 'Trail Rated' Badge, 06 Rear Overhead Lamp, 06 Tail Lights, Clear Turn Signals, and 160 Amp Renegade Alternator.
VTNomad is offline   Reply With Quote
Old 08-05-2006, 11:29 PM   #2 (permalink)
I say =D> and it's all thanks to
Daniel
firefighter5212 is offline   Reply With Quote
Old 08-06-2006, 10:02 AM   #3 (permalink)
Send a message via AIM to Eddo
Default Re: How to Improve your MPG
Actually, the #2 is only partially correct and #6 is incorrect.
More airflow simply mean your computer adds more fuel (more power, but not better gas mileage). This idea goes back to the old carburated days when there was no computer that meticulously monitored your fuel/air mixture and adjusted for conditions each millisecond. Back in the carburated days adding more air could lean up the mixture a tad and achieve slightly better economy. Combustion efficiency was no where near the 99% level it is today. An aftermarket air filter or high-flow intake really won't do anything from gas mileage despite with people say. You can always get more efficient airflow by opening up the throttle.
Decreasing backpressure can help gas mileage, beause it decreases the load on the engine. But in reality if you are cruising at 60mph and at 1800rpms the stock muffler is not that restrictive.
Higher altitude does NOT decrease gas mileage. You lose 3-4% power for every 1000 feet but not gas mileage. This is exactly the same argument as the air filter/high flow intake. You computer will adjust for the altitude and use less fuel. You will have less available power, but not less gas mileage. This idea also goes back to the carburated days when there was not really a way to dynamically compensate for changes in climate.
Actually, fuel economy can be slightly improved with altitude. Less air density means less air drag. At 5000 feet the density of air has dropped 10% hence the force of air drag has dropped 10%.
Modern automobiles burn about 99+% of the fuel injected into the cylinders. Combustion efficiency is about as high as it can be achieved. Other areas such as thermal efficiency, rolling resistance, drive train loses and air drag cause almost all the loses.
2003 Liberty Limited
Eddo is offline   Reply With Quote
Old 08-06-2006, 01:06 PM   #4 (permalink)
Default Touche
Good points.
Your computer can only add fuel too a point. A larger fuel pump and large diameter lines will be necessary.
I'm not sure why I was thinking altitude hurt your fuel economy. It hurts you horsepower. Alcohol has a way of playing tricks on you like that.
Old 08-07-2006, 01:56 AM   #5 (permalink)
Se7enLC's Avatar
Send a message via ICQ to Se7enLC Send a message via AIM to Se7enLC Send a message via MSN to Se7enLC Send a message via Yahoo to Se7enLC
I don't know if it's the same with the automatic transmission, but I would change line #1 to specifically state that the reason not to go fast is because the engine will rev higher. I'm not sure the exact level, but I heard that the 3.7L engine was most fuel-efficient at around 2200RPM, which for me is 6th gear at 65mph. I've tried going various speeds on the highway and resetting the overhead MPG gauge and found that 65mph is optimal (for 6th gear).
So to say it a different way, I actually get better gas mileage going 65mph than going 60mph or 70mph.
2005 Jeep Liberty Renegade, 6cyl 6spd manual, frankenlifted (OME), leather, Sony Clie GPS, MAGlite, Alpine CD/MP3 with iPod Changer, Thule racks, the works :-)
Se7enLC is offline   Reply With Quote
Old 08-07-2006, 05:02 AM   #6 (permalink)
Corwyyn's Avatar
Pretty much the same for the 3spd auto with OD on. I haven't actually tried driving extended distances at 65mph, but at 75 with cruise I can avg. around 22mpg. May have to take a road trip to see what 65mph does for me...
Kevin
'03 Flame Red Liberty
"A stick of dynamite to blow out the side of the tomb, scoop the bones aside, you grab the Amulet and you run"
I. Jones
American Journal of Archaeology
1932
Corwyyn is offline   Reply With Quote
Old 08-07-2006, 05:26 AM   #7 (permalink)
Marlon_JB2's Avatar
Kombat Edition Jeep
With my old red 3.7L Liberty...
65MPH would give me 24.0MPG.
70/75MPH would also give me 22.XMPG.
With this one? I don't know... probably the same. Grr.
MOCK005 likes this.
Old 08-07-2006, 07:42 PM   #8 (permalink)
Trodo's Avatar
Here's an intresting site that talks about a geat deal of the myths and such out there, like the magnets, typhoons, etc...
http://www.fuelsaving.info/
Silver 04 - 3.7
Edelbrock Exhaust / Rusty's KJ Tube & 5x8 K&N / Mopar Skids / Tow package / Pennzoil Syn / Cold Tire psi 35
(Mopar Bullbar, underdash Courtesy Lights, Webasto moonroof, Mopar Subwoofer, 05 AC controls, Scangauge II, Clear signals, Aux. Lights, 9145 to 9005, Double Mag mounts, USASpec Ipod Controller, rear gate pocket, Full Lloyd Mats, Filtermag, etc... Best Mileage 23.5 Hwy @ 75) JEEP Owner until the day I die.
Trodo is offline   Reply With Quote
Old 10-26-2006, 01:59 PM   #9 (permalink)
#7. Get another vehicle if you are worried about gas mileage
jeepHead and baer jeeper like this.
06 Renegade
KJgirl is offline   Reply With Quote
Old 10-26-2006, 02:31 PM   #10 (permalink)
MoladoGuy's Avatar
Send a message via AIM to MoladoGuy Send a message via MSN to MoladoGuy
=D>
X2
<b>--PHIL--</b>
<i>04' Columbia</i>
<i>(Lift, Wheels, Tires, Skids, U Know...)</i>
“Your barely even brown”
MoladoGuy is offline   Reply With Quote
